Temp Gauge not worky
Started by RamToy, November 22, 2007, 09:36:13 PM
RamToy
90 22RE
So i change my truck a little... Took out stock tank and put in fuel cell. Took off the front clip and moved the radiator in the rear... Everything works except the temp guage. It does not even register. Needle stays sunk down. I didnt pull off the water temp sensor or anything. Its in the stock location. Everything is plugged in. Anything I should look for ?
It use to look like a regular truck... Now it looks like this.
90 TOY SAS
Is your temp sensor in the thermostat housing?  I'd double check that the connector didn't get pulled off or the wire pulled out of the connector.
Hammerhead
Wow Ram, I haven't seen you on here forever, I figured you fell off the planet...
No help with the tech prob.  Just sayin' hi :wave:
'82 pickup, +3, locked, doubled
'82 pickup, IFS long travel, V8
'85 4runner, V8 rock crawler
'88 X-cab, V6
Cheesemaker
Check for the wire that is between the lower intake runners, right in the middle, right up against the flange that bolts to the head!  Mine wasn't hooked up, and the temp gauge didn't work.  And I thought it was the one in the top of the t-stat housing.
RamToy
Quote from: kneedownnate on November 22, 2007, 10:36:12 PM
Its in the front of the block. Not the housing... I checked the connector and its plugged in. Is there a way to check if the sensor is still working ?
90 TOY SAS
RamToy
Quote from: hammerhead on November 22, 2007, 11:34:52 PM
Hey hey !! Yeah its been a long time.. Rockrawl.com was almost cool. haha !!
90 TOY SAS
RamToy
Quote from: cheesemaker on November 23, 2007, 02:09:06 AM
Ill try to look for a loose wire there tonight....
90 TOY SAS
RamToy
No wire there. ... No where for a wire to hook up.
90 TOY SAS
93tonkatoy
This FSM will show how to test the gauge itself. http://personal.utulsa.edu/~nathan-buchanan/93fsm/bodyelectrical/6combinat.pdf Page BE-36 right after the fuel gauge tests.
I believe to test the sender, you will need to check the resistance of the sensor with a ohm meter while the engine is cold. then warm the engine up and check the resistance again. it should be lower. If it is not, replace the sender.
SAVE TELLICO post 491
RamToy
90 TOY SAS
