Author Topic: G58 adapter  (Read 2167 times)
yp_urslf
  • Member since Nov '07
G58 adapter
« on: Nov 20, 2007, 06:48:37 PM »
im looking for an adapter to mate a G58 tranny with the transfercase off of a W56 tranny.  marlin make one?
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
Re: G58 adapter
« Reply #1 on: Nov 20, 2007, 07:17:46 PM »
have you tried  to just stick it in there :dunno:  but i think they have the same bolt pattern
Re: G58 adapter
« Reply #2 on: Nov 20, 2007, 07:18:26 PM »
btw  i would use the w56 tranny also if you have one
yp_urslf [OP]
Re: G58 adapter
« Reply #3 on: Nov 20, 2007, 07:34:15 PM »
i dont have it yet, so i cant really look at it to see if it'll work.  heres my situation:  i have a 90 4runner with a G58 and chain tcase.  i can get a dual gear driven tcase setup off of a W56 tranny.  i'd like to keep my G58 if i could because i know nothin is wrong with it and it shifts fine, i can get the W56 if i need to, but i need to buy it all at the same time if i need the tranny also.
Re: G58 adapter
« Reply #4 on: Nov 21, 2007, 11:34:21 AM »
i'll get ya  someone that knows for sure  :thumbs:
  • Administrator
  • Turtle Points: 2205
  • Male Posts: 18,292
  • Member since Apr '02
  • 511:1 Club
Re: G58 adapter
« Reply #5 on: Nov 21, 2007, 01:39:46 PM »
Negative.
An adapter could be made, but I believe that it is more work than what it is worth. For starters, the G58 was only offered from 1989-95 in trucks that had Autolocking front hubs for 4WD shift-on-the-fly ability, which limits the amount of customers we see who need parts for a G58. But more detrimental to this problem, is that the transfer case shift rail height is lower for the G58-chain drive t/case setup than with the RF1A gear drive t/case setup, so even if we did make an adapter to put a gear drive t/case behind a G58 transmission, we would either need to make customer shift rails to account for this height offset, or we would need to make a special shifter that had a longer throw (which no one would want).
So in general, we strongly recommend you to consider upgrading (a W56 is stronger than a G58) to any W56-type transmission from 1985-99, understanding that there are two basic models available, one from 1985-88, and the other from 1989-95, short and long forward shift t/case rails respectively.
Regards,
yp_urslf [OP]
Re: G58 adapter
« Reply #6 on: Nov 21, 2007, 07:28:35 PM »
ok, thanks alot bigmike.  and a W56 would bolt up to my motor with no problems?  even the slave cylinder?  thanks again, its hard to find info on the G58, i guess no one (including me) wants one.
Re: G58 adapter
« Reply #7 on: Nov 22, 2007, 04:33:24 PM »
when you get the w56  try and get the clutch fork  and  throwout bearing parts
Total Distorsion
  • Turtle Points: 87
  • Member since Nov '04
Re: G58 adapter
« Reply #8 on: Nov 24, 2007, 09:35:49 AM »
I just ran into the same problem, sort of. The tranny in my 85(w-56) is making noise in reverse, so I was going to swap it out with a tranny my friend had. It turns out its a G-58. I was looking all over for info but all I came up with that it has 26 splines vs 21/23. I didn't know about the shift rails. Maybe I'll just rebuild it.
Last post Dec 28, 2004, 09:26:10 PM
by ksto
Last post Nov 30, 2005, 06:58:23 AM
by Thumper
Last post Aug 12, 2017, 08:51:37 PM
by TURBO
Last post Dec 03, 2010, 03:43:33 PM
by muddytaco
Last post Jan 04, 2011, 10:47:34 AM
by vaj70cruiser
