toyota turbo diesel???
Started by 79coyotefrg, May 29, 2004, 05:14:51 PM
did the 2L ever have a turbo,  and how hard are they to find??  whats that aussie  ,  1kzte ??
I think that 84 and 85 were the only years that had the turbo as an option and they came equipped with a w56 instead of a g58.  Of course Marlin would know way more than I but at least thats a starting point.
Bazzi
There is 2lt  = a turbo version of the 2l I do not know what year it fyrst came, but it is also possible to put a turbo on that engine. Here in Iceland it has been done a number of times,
You can put the orginal turbo CT20 onto that engine but You have to be carefull not to put to much preassure into the engine 7-8 psi I thing is the preassure to set.
There are several others things that You have to do to be safe (but it is hard for me to descripe them because of my bat english)
Prismo
Your english seems to be better than Brainless. :yupyup:
brainlessfool
Marlin
85' was the first and only year for 4x4 turbo diesle and yes, the turbo got the W56.
84-85' 4x4's got the G52.
I have only seen 2 turbo trucks------------
Marlin
Native Warrior
I have a 84 Toyota 2L truck Non turbo can you give me the engine specs for this truck please? What transmission I have, gear ratio, and also what can I do to keep it from getting overheating the cylinder head again. I bought this truck with a cracked head and I bought a new one. I would like to remedy this problem of overheating. Do I get a better exhaust system, it's still got the factory exhaust on it do I make it a 2" exhaust or 2.5" even better for heat problems?
Wainiha
where is the Aussie member on this question?  Hilux Max?
2000 3.4L xtra-cab Tacoma.
Icon C/Os
Marlin 1200lb. clutch
Marlin short shifter
FLOODED...GONE
2005 4.0L xtra-cab Tacoma
FLOODED...GONE
2012 4.0L xtra-cab 4x4 Tacoma
Automatic...Don't shoot...
King resi C/O
and Total Chaos UCAs
