Another problem
Started by lilbuddy, November 18, 2007, 08:32:20 PM
85xcab
How about a loose ground going from the chassis to the engine? When engine torques up due to going in reverse or slowing down in gear it is breaking the ground circuit.
lilbuddy
Quote from: 85xcab on November 20, 2007, 02:07:43 AM
I think you are right and that could be the winner.....
The reason for this is that when I backed it up my driveway (in low low and it still kept dying cause its such a steep driveway) and since its under a load the motor is torquing ... I htink that when i back it up it does it mainly cause like you said it is loose and doesnt have a good ground and causes it to die...
Another thing when i backed it up and left it in reverse since the motor torques "off" the right side motor mount (where the ground is) it doesnt have a good ground and dies but when i left it in reverse on my steep ass driveway it pegged the temp gauge up past the red and the volts were like at 6-7....
Im checking the grounds later. I think that is the lucky winner though.
RIP Kyota.... you are the man
GET IT!!!
lilbuddy
And the winner is.......
85xcab
The ground from the head to the body was all fagged off. Got it fixed and its good to go!
GET IT!!!
KDXSR5
dang :down:  i read thru this all  and you done fixed it  :headshake:
at least you can :driving:
lilbuddy
Quote from: 79coyotefrg on November 25, 2007, 12:39:49 PM
Sorry to disappoint you :yupyup:
GET IT!!!
Hammerhead
No Glen, it doesn't mean he can drive, it just means his truck runs good again...  :hahaha:
'82 pickup, +3, locked, doubled
'82 pickup, IFS long travel, V8
'85 4runner, V8 rock crawler
'88 X-cab, V6
Quote from: hammerhead on November 25, 2007, 11:02:53 PM
:haha:
