springs??
Started by konatoy, May 28, 2004, 02:05:59 AM
konatoy
what is the cheapist, not too cheap, still want really flexable, but anyways whats a great spring combo or what kits are any good, i want something like a 5 inch lift, but i want to keep it cheap. Could someone explain to me how the chevy swap, works, and what "Chevy" model, n year i would need, and if thats a good alternative??? Also hows the rear shock hoop things are they any good? help me out with a flexable, but cheap suspensions setup. Thanks for all the  :help:
BLUCRUZ
I run Rancho 44044's up front. They seem to be very popular and cheap-combine them with 1.5" lift shackles and you got a 5" lift up front.  I run All pro 56" 5.5 inch rears and like them. They've sagged almost 2.5 inches though over time so I've added longer shackles. the whole setup seems to be real flexy.
72 FJ40. 350 Multiport EFI, turbo 400, ORION T-case, 35 Procomp's  disk brakes front & rear, ARB's F&R and an onboard shower for the ladies!
86 sr-5 4runner SAS conversion. E-lockers F&R, 5.29's 4.7 Marlin case.
GRM
Assuming you already have high steer, longer shocks/mounts, longer brake lines etc. A really cheap effective option is 79-88 toyota 4wd rear springs mounted in the front (need to add 2 or so leafs out of another pack, I personally put in 2 leafs out of an 84 4wd rear pack into my 83 pack (79-83's use a 18mm front hole like the stock yota fronts instead of the 14mm used on 84-88s). Also, you need <4" long shackles. I personally run 7" long shackles.
For the rear, Mazdas, 88-98 chevy rear springs, f-150's, etc all seem to be good choices. I have a set of 88-98 chevy 3 leafs with the stock overload, 6.5" shackles, and a 2.25" block, and they work great for how I use the truck.
Actually, the suspension is very well balanced on my truck as it sits, and I really recommend it.
superstarai
 How do you put the rancho 44404 springs or whatever its called up front?
Brandon
Quote from: superstarai on June 01, 2004, 10:05:43 AM
how do you put on a wheel?
you unbolt it and bolt the new one on ;)
:yupyup:
Wagoneer springs front and rear work great, stockers are fine..
Just need a longer shackle. You can do more but that will work..
Brandon Miller
RCRC, Sacramento, CA
www.RiverCityRockCrawlers.com
superstarai
 So i just unbolt my front springs and bolt on the rancho 44044 springs and had a longer aftermarket shackle in the stock shackles place?
superstarai
  Do u know how much they cost or whats the best shackle to put on the front with rancho 44044 springs? And what lift of spring do u use or what do they offer thanks. Do you think that they could be used for the street too?
They'll cost ya about $225 + shipping from summit.  Id use a 6-7" shackle.  Yes they can be used on the street.  Hell Kyota just drive them 1200 + miles w/o a problem
Brandon
44044 is the rancho part number for a lift spring for a jeep wagoneer
Brandon Miller
superstarai
 What kind of shackle though and if its 5" i could use 37" tires! But might hurt my stock axles. It sounds like a great idea anyone used the toyota rear springs in the front any success? I might want to try that too and how much lift would i get? And how would i put those on? Just curious thanks for your help.  :beerchug:
Brandon
if you never drive off road sure ya can..
My axle is moved forward, dropped, with an extended shackle and a body lift. Fenders are chopped and the body is tubbed and they still rub HARD..
Brandon Miller
Brandon
this was taken the first week I put them on, so they are brand new in the pic. They work much better now ;)
oh yea, those are only 35's - dropped front hanger moved forward and a body lift..
Brandon Miller
superstarai
 I wish i was their man that looks fun i cant wait to get my resort managment job and staring working and buying parts for my truck and start wheeling like crazy with u guys :thumbs: :beerchug:
derek
stock rears in front work great also.
need to add some leaves to them, found about a six leaf pack works best.
they move your axle forward 2" or so.
i run them and a 3" body lift and clear my 38"s with no rubbing.
i will post a poser pic when i get home.
unless brandon still has the poser shot of me and dave on the ramp at prairie city on his site?
both dave and i run toy rears up front.
derek
superstarai
 Would i have to do some firewall clearnce stuff since it moves my axle 2"? Yes or No? Also how much lift would i get on a stock rig and do i just bolt them up? Thanks
derek
they move your axle forward away from the firewall.
i didnt have to do any trimming since i have a body lift also.
but with no body lift you may need to make some room with a BFH.
derek
Brandon
Brandon Miller
Brandon
stock wagoneers on the white one and 44044's on the other one (mine)
Brandon Miller
derek
yup those pics.
thanks brandon.
only had 35"s on at the time though.
now run 38"s with the same setup.
derek
derek
full width helps a ton also. :eyebrow:
get more leverage on the springs.
i still run toy width. :talkingn:
derek
Brandon
Quote from: derek on June 02, 2004, 02:54:10 PM
derek
heavy axles keep em all on the ground :)
I am 80" total width outside of tire to outside of tire which is about the same as a yota with 2" BS
Derek has chevy's in the rear too - I'm about to swap out my rear and go with wagoneers I think.
Brandon Miller
superstarai
 So the toy rear springs just bolt up to the stock front stuff? Your guys rigs look sick! I wish i was there too! So i can but rancho 44404  springs in the rear? THanks again for all your help and hope to get out there soon and wheel with you.
Brandon
Quote from: superstarai on June 03, 2004, 09:33:24 AM
wouldn't put em in the rear, I'd use the rear springs for a wagoneer (fronts are 44044). I'll be using stock ones from the pick n pull. That white 4runner uses stock fronts from a wagoneer and stock chevy's in the rear - all pick n pull stuff.
Brandon Miller
derek
either spring will bolt in the front. but will most likely need some lift shackles.
44044's in the rear would probably work ok, but i dont personally know anyone running them that way.
f-150 or chevy springs seem to be popular. the chevys are a little long and the mounts for them can get hung up.
f-150 springs are shorter than the chevy's and seem to flex real well in the rear.
derek
Brandon
#25
they are a tad wider (2.36 or something vs 2.5") but I hear you can cram em in there. I used jeep hangers and since they are jeep springs they worked great.
There is some great info here: http://4x4spot.com/misc__spring_information.htm
the wagoneer front and the toy rear are the exact same length so it seems that replacing the stock rears with wagoneer fronts wouldn't do much..
Rear wagoneer springs are about 9" longer on the other hand..
I don't see the ford ones listed there though, I'd be curioust to know what their specs are..
The lift shackles up front aren't necessarily for lift - they are so the shackle doesn't bottom out against the frame since the springs are 3" longer than the stock toyota ones.
Brandon Miller
superstarai
 I know what i want to use now for my suspension i want to use my toyota rear springs up front 48" and mazda 52" or wagoneer 6 leaf 57" in the back. Whats the best shackles to use? For these springs let me know otherwise i might use teraflex relover shackles, bfe offroad shackles, joinny joint shackles from allpro, or 4crawler products shackles. THanks again for all your help. I would like to use 14" shocks with custom mounts. THanks again. See ya out their in the future i hope. :bowdown: :thumbs: :beerchug:
Brandon
depends on your budget, mine come in the way of a flat piece of steel cut to length with 2 holes drilled in them ;)
Brandon Miller
For rear springs i would go with 88-98 rear chevy springs.  They can lift it anywere from 1 1/2 inches to 3 inches depending on what they come off of.  The best would be a 3 leaf from a 2 wd.  The other ones will work too.  You can use the double shackle style with a longer shakle and gain 5 inches easily.  For the rear the cheapest would be your stock rear springs since you probly already have them.
superstarai
 THats a good idea but i still want to use the stock rear springs up front can i drive it on the street? I changed my mine about the rear i think i might go with someting else like deaver or all pro or aor. I just dont know if i want to use chevy springs or anything chevy on my truck no offense just dont like it. :nope:
