I have an atlas 4speed, and my low low is just over 10to 1 and my sm465 has a granny low of almost 7 to on....I just did a general search to find the exact ratios in my tranny, and since i configed my t case and axles I already knew.. How do you guys like your gear ratios, are they too low, too high, or perfect?
i dont know how my truck works yet, have never driven it
Tranny =6.58:1T-case =10.34:1Axle =4.10:1Total = 278:1
The only disadvantage I see to your set-up is that when you go into "low" your extremley low. The advantage to having the dual cases is that you can select how low to go. I know your trying to stuff all this in a Jeep, so space is at a premium. I used to have a Chevy Blazer with the SM420, and that 1st gear is a crawler. Fortunatly 2nd gear is low enough to start out in, so you'll have some flexibilty with that.I think you'll be very happy with your set-up, and you'll get around the disadvantages, and excell with the advantages. Erik
between the gears(513s) stock tranny(r150) and dual cases(2.28&5.0) my crawl ratio is around 250to1
how do you find your crawl ratio? do you get the numers in the first post and multiply them all together or what?i gave you +1 since your jeep is pretty bling
that thing is sick.... thanks... i need to now find the right numbers to plug in there
i take it i leave the crawl box ratio blank?
sorry about that i was referring to the whole thing not just gears
better...thankswhen i get my duels it will be a lot better... stock front case with the 4.7 in the rear or visa versa not sure... cant wait though
Thats some intense crawlin!! Is there anyone that has some more extreme ratios, do you ever use the really really low?I know this is off topic but what keeps the drivers tire on the jeep from droping? Is it the pitch of the climb, torque of the drive line, suspension or what?
Started by pistolpete_biker General 4WD Discussion
Started by MT-Tom General 4WD Discussion
Started by Hawaii-EV Engine
Started by GDubb5150 General 4WD Discussion
Started by Rock Rat 2 Axle/Differential/Steering
