95.5 and newer R150 info needed
Started by Yoda_Man, May 26, 2004, 10:30:06 PM
Yoda_Man
can anybody tell me the length of a 95.5 R150 tranny also the overall lengh of its input shaft.
1/2 85 toyota 4x4 + 1/2 turbo supra = ALL TOYOTA
Marlin
Instead of guessing, I will measure and post tomorrow a.m.
Marlin
Marlin
#2
The trans is 26" long with the redesigned air cooled clutch bellhousing.
The eariler 88-95 R150F is 25" long.
The input is 1 inch longer to match the longer release bearing. Both trans use the same pilot bearing, clutch hub spline, fork, and bellhousing pattern.
I have successfully mated a R151F to a 2000 3.4 V6. I had to machine the clutch piviot base and releive the nose cone for clearance.
Marlin
Yoda_Man
my idea is to use the (stronger and better geared)95.5 and newer R150 with the bellhousing off a R154 to mate to my 7m-gte.  as for the transfer case id prob buy an adapter from you.
marlin,  do you know if the bellhousings from all the R150's are the same?? bolt pattern just different lengths?
neil
Marlin
All R series trans use the same 9 bolt pattern on the face of the front transmission housing so the 7m-gte bell would bolt right up :thumbs:
As long as your bell is 7 1/4" long, your in luck.
To my knowledge, there are only 2 input lengths. Orginal [standard], and air cooled [long].
Marlin
jr9162
Marlin,
Can one swap the 99.5+ Taco R150F input shaft (just the input) into a R151F, keeping all the R151F's gears (ratios) intact?
JR
I'm a member of P.E.T.A.
People Eating Tasty Animals
There's no nookie like chinookie
No butts like halibuts
Fish are not our friends, they're food.
Eat more moose - 10,000 wolves can't be wrong
Calling an illegal alien an "undocumented immigrant" is like calling a drug dealer an "unlicensed Pharmacist".
