91 extra cab truggy
Started by Lizard_lips, November 09, 2007, 03:18:18 PM
Lizard_lips
I have a 91 extra cab toyota with a exo, It's a rolling chassis. Clean title. steering box moved forward and steering shaft lengthened. set up for fullwidth axles. toy rear front springs and 1/4 ellips rear. but not links yet. all harness for a 22re, gas tank between the frame and frame cut behind the cab and tubed. Fullwidth dana 44 front all new bearings and seals 4.10 limited slip, flat top knuckles drilled for hysteer arms. 14 bolt rear 4.10 detroit and some 38x12.50x16.5" swamper sx on 589 16.5x10" wheels and a sm465-np205 combo and small block 350 that needs a rebuild if you want it. I was looking to get $2000
I also have some extra 57" fords, a bunch of drive shafts, A hydro ram and lines, and new vortec heads, some intakes, carbs and a np 203 t-case I'll sell with it for an extra $500
$2500 with everything.
Located in Las Vegas
The statistic on sanity is that One in every four is insane, Think of your three best friends if they're ok then its you.
Lizard_lips
willing to part out.
$800 for the body, exo, frame, and suspension.
$450 for the tires and wheels
$750 for the axles
also have the hydro lines and ram for sale and all the misc parts I listed
all prices are best offer.
__________________
CrawlerBrennan
Lets go camping
Lizard_lips
I might have a sale pending on the whole thing. I'll let  you know if it doesn't happen
yodasrnr
SO CAL ALKY ASSOCIATION
