Total Chaos IFS Suspension (or something similar)
Started by NorCalToy, October 30, 2007, 08:49:43 PM
NorCalToy
just trying to see if anyone here is running the Total Chaos kit or something like it. Its a long travel kit for IFS, just wanted to know whether or not its worth it and wat the price for the kit even is.  this is the kit im looking at: http://www.chaosfab.com/95200.html
:flamer: IFS
they are quite expensive, but TC is the top of the line for ifs....
NorCalToy
i found a few others too. but TC doesnt list a price for there kits.
:flamer: IFS
i beleive their basic kit is around $2500, then their are upgrades you can add
they are quite expensive but the best in the business.... beware of some of the other so called companies, there are a lot of sub-safe companies out there
NorCalToy
yea those kits are awesome. anybody know how they do when crawlin?
:flamer: IFS
93tonkatoy
Make sure to look at what is NOT included in the kit. coil-over springs, t-100 axles. Those may also get pricey on you. And for the same approximate price, you could probably have a shop do your sas for you.
SAVE TELLICO post 491
NorCalToy
shop and SAS would probably be pretty close price wise. coilovers are pretty expensive. i need to find the base price for the Caddy II kit so that i can plan a "budget" of how much it would cost to do. still need coilovers, glass fenders, T-100 axles.
but it would be utter badassness.
:flamer: IFS
what are you plans for the truck, what kind of driving do you do?
properly setup, onroad, an sas can still be quite nice...
do you run through desert washes @ 70 mph? or do you rockcrawl?
you will receive tons of responses on everything, both can be great, in their own right, both can do fairly well in another realm as well... but build to what you are capable of and for your propsed use of the truck....
NorCalToy
well, theres not to much desert here, but thers not enuf rocks to really use the full potential of an SAS. My thought were that if i got a longer travel IFS system it would be able to handle some lite/moderate crawling and still be fun on all the forest roads. plus ill probably go to college in arizona (UTI,MMI,etc.).
:flamer: IFS
BLACKDOG
Unless you plan on bombing around the desert at 60+, the TC kit is prolly more than what you'd want to spend.  Last I checked, their base kit was right around 2K, and that was a while ago, and that is just the bare bones kit, you've still got to scrounge up the other stuff yourself.
On a side note to the IFS, you don't necessarily have to pay a shop to do the SAS for you, you can have them weld up the front hanger, and the shackle tubes for you (without cutting out the IFS) and then you can do the rest of the stuff (wrenching, cutting/grinding/torching the IFS) yourself.
              -Ronald Reagan
NorCalToy
yea i can get the SAS done without a shop, i think he was just comparing the price of TC to the SAS being done by a shop. i have the resources to get the SAS done, i just like the IFS long travel.
:flamer: IFS
CADD MAN
TC is totally top of the line for IFS, with the caddy kit (gen 1 i believe) my buddys 3rd gen pulled about 13" of clean travel in the front.  He hammered that poor truck we jumped it way big at speeds quite a few times to this day its still holding up and runnin strong.  He wasnt runnin 4wd witht the T-100 axles but the travel would be slightly less if he was like around 12" I think.  I would say that with the kit and coilovers shock hoops and bumps you would be in around 4-5k.  From what I have read though guys that keep the 4wd love it and say it wheels nice in the rocks and trails, and they can bomb in the desert too.
NorCalToy
thats wat i needed to know is how much it is to complete the kit with 4x4 and the glass fenders, and the kit.
:flamer: IFS
NorCalToy
this is flex with the basic caddy ball kit. dont know if thet i max or not, but looks like a decent amount of flex
:flamer: IFS
CADD MAN
Quote from: viperred89 on October 31, 2007, 03:48:43 PM
I would think you would be in around 4 or 5 thousand for the kit, coil overs, c/o mounts, glass, t-100 axles.
NorCalToy
dam. i expected it to be expensive, but thats a lot.
:flamer: IFS
46&2
Quote from: CADD MAN on October 31, 2007, 09:02:04 AM
X2. I have a friend that had this kit on his baja truck and it was a sick kit. We blasted through the whoops and jumped it going 50 mph + and it felt like we were mall crawling it was so smooth. He never used it for crawling because he only had 2WD but it was the smoothest toyota I had ever ridden in at high speeds over washboard roads, dunes and whoops. You are looking at 4-5K with the fenders and t100 axles and other necessary items. If you think you are going to do a lot of heavy abuse, high speed driving this kit is for you. It also works great for 4 wheeling as it offers plenty of wheel travel. It is meant for fast, hard abuse though.
NorCalToy
RokCrawlinToy found me a site where the TC kit is sold, they offer options to complete the kit. as far as i can tell its gonna be $2743.00 plus tax and shipping to completly complete the kit. here is the link to check it out if you want: http://www.polyperformance.com/shop/product.php?productid=221&cat=602&page=1
this is without the t100 axles. i would add those in when i needed 4x4. maybe in the winter.
Quote from: fortysixandtwo on November 01, 2007, 08:53:37 PM
which kit did he run ball joint, caddy 2, or caddy 3?
:flamer: IFS
46&2
Quote from: viperred89 on November 02, 2007, 11:53:11 AM
He ran the first generation caddy kit. It is the forerunner to the current Caddy 2 and Caddy 3 kits. Basicaly the same thing as the Caddy 2 they offer presently.
NorCalToy
thats wat i would probabaly run. looks to be about the same.
:flamer: IFS
CADD MAN
I priced one out on there and it was $3586 or something like that bit it had all the goodies, prerunners are expensive and the little stiff not included will add up as well of the top of my head you will need:
Bumps air, hydro or poly
Limit straps
Glass hood (may as well looks better with the fenders IMO)
Dezeuse fasterners for fenders
T100 axles ( if you go that route but junkyarded they are not bad)
Then with all that front suspension you will quickly want rear, back end will buck something fierce stock with that up front.
So: Deaver springs
double bypass shocks
limit staps
Bumps
Then you should cage it just to be safe!!
I am sure there is more but thats all I can think of for now, like I said before prerunners are expensive, but worth every penny when your mobbin over jumps at 50+mph in the desert. :twocents:
roadcrawler
i read as much possible on total chaos an what i gathered was they are strong, but they are gonna need a allignment quite often, an it never fully is correct, your alignment is always off. but thats just me an my interpratation of the facts....good luck.
before my 85 died, due to me not it, i did the exact thing a pre runner could do, but my front was so much stronger than a pre runner front, i jumped my truck an baja-ed it at 45mph on single track over rocks an thru ruts, but at the end of the day i could outwheel a pre runner
thats just me
NorCalToy
i would imagine that it is always out of alignment, smashing on that :pokinit: doesnt do good things for it. i like the tundra hood setup, it looks badass. ill try to find a pic.
:flamer: IFS
NorCalToy
pic. with the tundra front clip
:flamer: IFS
NorCalToy
i like the giant motorsports beam kit. it is :boobs: like super mega :boobs:
:flamer: IFS
NorCalToy
i found a video on the TC website, it shows an xterra and a 4runner, the 4runner part is all crawling using the TC kit, its the second half of the video. link is : http://www.chaosfab.com/media/video2.html
:flamer: IFS
46&2
Quote from: roadcrawler on November 06, 2007, 09:37:03 AM
thats just me
I agree with the alignment part, if you really beat the crap out of it is going to need a lot of tweaking and of course it will never be quite like stock but the street handling isnt that bad.
I do dissagree though with the solid axle - vs - TC...if I did the things my buddy did with his TC equipped truck....my front end would be jacked. Dont get me wrong I hammered the :pokinit: out of my 4runner before I swapped suspensions but it just aint the same as the TC suspension. The solid front axle with the right suspension set up isnt bad or weak by any means. but if you want to do consistant, smooth and controlable high speed action the TC is far superior to a solid axle. We jumped his truck at Sand Mountain in Nevada a total distance of 25 feet with about 10 feet of air at the highest point off of a sand dune....and hammered down the rest of the day without any breakage except tearing the battery out. I thought the truck was going to explode on impact but it was actually pretty smoth all things considered. I will get the picture one of these days and scan it so you can see just how far high the truck was sailing.
The TC kit cannot be under estimated, it is awesome and if you are going to use it, its well worth the heavy price tag.
