Author Topic: rocker arms  (Read 4816 times)
bad luck
  • Turtle Points: 897
  • Male Posts: 271
  • Member since Sep '07
  • sas!
rocker arms
« on: Oct 13, 2007, 01:31:40 AM »
any one now if there is after market rocker arms for the 22re motor  :willynilly:
highridin4x4
  • Male Posts: 237
  • Member since Oct '06
Re: rocker arms
« Reply #1 on: Oct 13, 2007, 07:24:50 AM »
Yes. What kind are you looking for? I bought mine from the local machine shop. there are some on ebay for 80.00. Are yours steel or aluminum?
Scott
« Last Edit: Oct 13, 2007, 07:35:41 AM by highridin4x4 »
abnormaltoy
  • Turtle Points: 714
  • Male Posts: 640
  • Member since Jul '03
  • I'll do the thinnin' around here Baba Looey!
Re: rocker arms
« Reply #2 on: Oct 13, 2007, 11:11:16 AM »
I got mine from www.engnbldr.com on ebay.
-- Winston Churchill
Travis Tritt (I know!)
RN37DD
  • Male Posts: 742
  • Member since Apr '07
Re: rocker arms
« Reply #3 on: Oct 13, 2007, 04:52:18 PM »
if they are steel someone slipped in some 20r rockers. i got my aluminum rockers from an 83 22r. they were in perfect shape.
oddball
  • Turtle Points: 1143
  • Male Posts: 952
  • Member since Jan '05
  • Weirdo
Re: rocker arms
« Reply #4 on: Oct 15, 2007, 09:01:31 AM »
Whats wrong with the stock ones?
bad luck [OP]
  • Male Posts: 271
  • sas!
Re: rocker arms
« Reply #5 on: Oct 15, 2007, 09:07:54 AM »
i was hoping to get alittle more hp from my motor
RN37DD
  • Male Posts: 742
Re: rocker arms
« Reply #6 on: Oct 15, 2007, 09:23:48 AM »
i don't think they make ratio rockers for the Toyota. but even if they did, it would still be cheaper to change to a better cam. the stock aluminum rockers are good. LCE has a few cams that well give you a little more hp. tons of after market cams out there.
oddball
  • Male Posts: 952
  • Weirdo
Re: rocker arms
« Reply #7 on: Oct 15, 2007, 09:28:45 AM »
X2 on the cam, your not going to get much if any improvement from aftermarket rockers
bad luck [OP]
  • Male Posts: 271
  • sas!
Re: rocker arms
« Reply #8 on: Oct 15, 2007, 09:33:26 AM »
in my opinion i relly don't like friction in a motor
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
Re: rocker arms
« Reply #9 on: Oct 15, 2007, 09:34:16 AM »
theres  no  "roller" rockers  if thats what you wanted,
your best bet is OEM  toyota  rockers
had a friend use  NAPA  rockers  and  his  rub pads  broke off  in the middle of  a  wheeling trip
:headshake:
bad luck [OP]
  • Male Posts: 271
  • sas!
Re: rocker arms
« Reply #10 on: Oct 15, 2007, 10:39:13 AM »
well that wood be nice if somone made rollers
RN37DD
  • Male Posts: 742
Re: rocker arms
« Reply #11 on: Oct 15, 2007, 12:36:00 PM »
even roller rockers have their dark side. more weight, more parts, higher cost and more stuff to brake. the rocker i took out of an old 22r had zero wear on the hardened cam pads and it only cost $6 each to replace the valve adjuster side with new Toyota screws. the cam still looks perfect too. yeah some cam manufactures try to scare people into always replacing them. but if they're good, they won't be better just because they're new.
*ROKTOY*
  • Male Posts: 1,066
  • Member since Nov '06
Re: rocker arms
« Reply #12 on: Oct 15, 2007, 02:59:26 PM »
If you run old rockers on a new cam you stand a good chance of wiping out the cam. Not to mention it will void your new cam warranty.
RN37DD
  • Male Posts: 742
Re: rocker arms
« Reply #13 on: Oct 15, 2007, 03:19:49 PM »
yes if the old rockers are worn. like they were on my 20r. but what completely amazed me was how destroyed they were and yet the cam was not damaged. and yes i backed away from buying an LCE cam because the threat on not being covered under warranty... so I'm running a cheaper cam  with no warranty, that's quite happy with the old rockers.. should have trusted my judgement and bought the LCE cam.
*ROKTOY*
  • Male Posts: 1,066
Re: rocker arms
« Reply #14 on: Oct 15, 2007, 05:23:28 PM »
All used rocker wear, each rocker develops its own wear pattern to the lobe on which it is run, even if you can't see visible signs of wear.
RN37DD
  • Male Posts: 742
Re: rocker arms
« Reply #15 on: Oct 16, 2007, 09:16:22 AM »
check this out.. this came out of a r20 that ran from 79 to  07 and was still doing 6000rpm down the road when i pulled it apart.. had a hard life even threw a rod at one time and had the crank re welded. and someone removed the stock cam and slapped in a crane cam.
emsvitil
  • Turtle Points: 7571
  • Male Posts: 3,561
  • Member since May '07
    • emsvitil's album
    • Buy me a soda
Re: rocker arms
« Reply #16 on: Oct 16, 2007, 01:30:24 PM »
On a old 20r I rebuilt (steel rockers), I just reground the followers with my bench grinder.......
Didn't have any problems with my 'rebuilt' rockers or the cam
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
RN37DD
  • Male Posts: 742
Re: rocker arms
« Reply #17 on: Oct 16, 2007, 02:40:24 PM »
yeah i find it interesting because the newer 22r rockers have a bigger harder pad that rides on the cam. i'd think it would do even less damage to a cam lobe, than the old 20r rockers.
*ROKTOY*
  • Male Posts: 1,066
Re: rocker arms
« Reply #18 on: Oct 16, 2007, 05:01:16 PM »
Reginding your rocker is like running new, when they are reground it removes the old wear pattern.
DAWGTOY
  • Turtle Points: 460
  • Male Posts: 212
  • Member since Jul '04
  • aint too old & broke up to sit down yet
Re: rocker arms
« Reply #19 on: Oct 17, 2007, 07:49:53 AM »
let me chime in here. i'm the guy that had a rocker arm
fail while on a trail ride. the rockers on my truck were
china made reproductions. actually napa came to my resciue.
on my way back from arkansis i stopped at a napa in mempis.
and at lunch i had a rocker in my hands. installed it in a state
park parking lot and drove on to kentucky. wheeled 3 days at
land between the lakes orv park. napa saved my vacation.
btw i got a set of new genuine toyota rockers ready to install
after this weekends harlin trip. and i'll always have a spare
in my toolbox too.
dawgtoy
1983 TOY SHORT PICKUP .35/12.50S EXO CAGE HOMEMADE BED CAMO PAINT, REARS UP FRONT CHEVYS IN THE REAR, 4 WHEEL DISK, CABLE LOCKER REAR, LOCK RITE FRONT, 5.29GEARS FRONT & REAR.BOBBY LONG 30 SPLINES 9500 lb WARN WINCH. DUAL
T CASES WITH 4.7 IN THE REAR. THANKS MARLIN
RN37DD
  • Male Posts: 742
Re: rocker arms
« Reply #20 on: Oct 17, 2007, 09:10:08 AM »
genuine Toyota rockers :thumbs: were you able to change that rocker with out removeing the head?
BUDDERS
  • Turtle Points: 15
  • Male Posts: 1,335
  • Member since Jul '05
Re: rocker arms
« Reply #21 on: Oct 17, 2007, 11:20:15 AM »
Why wouldn't he be able to?  As long as you don't try to lift up on the head (separating it from the headgasket) your fine.  I've done it several times while swapping in cams and never had a problem.
DAWGTOY
  • Male Posts: 212
Re: rocker arms
« Reply #22 on: Oct 17, 2007, 11:28:04 AM »
yea i removed the rocker assembly without ramoving the head.
not a problem. just don't spin over the engine or you will
damage the head gasket.
lucky dawg
RN37DD
  • Male Posts: 742
Re: rocker arms
« Reply #23 on: Oct 17, 2007, 12:55:28 PM »
thats why i asked. i plan on changing my cam. a lot of people say you should replace the head gasket if you loosen up the head. I'd rather not. so if ya got any secrets let me know.
BUDDERS
  • Turtle Points: 15
  • Male Posts: 1,335
Re: rocker arms
« Reply #24 on: Oct 17, 2007, 03:33:03 PM »
Make sure you drain the coolant and oil out of it before removing the head bolts.  If you don't those holes will get fluid in them and something will crack or strip when you put the bolts back in.  Even after you drain the fluids and remove the bolts, make sure you blow out the holes with compressed air and clean any nasty threads on the bolts - or replace the bolts.
Last post May 15, 2004, 10:28:07 PM
by Marlin
Last post Mar 14, 2006, 04:20:25 PM
by toymech
Last post Jun 10, 2006, 06:44:04 PM
by 79coyotefrg
Last post Apr 25, 2009, 04:12:34 PM
by kdo58
Last post Mar 17, 2020, 10:48:44 AM
by sirdeuce
