http://www.pirate4x4.com/forum/showthread.php?t=618045&highlight=crossed you could do this one. i have the front version and it is beefy. shipping was 45 to my house in central ca
those are sick axles..not a bad price either ...personally i would just pick up another stock one and beef it up a bit....people are practically giving away rears over here
kneedownnate I love your avatar
and will half tube the lower axle tube with 1/4 wall 3 inch tube where it typically bends
im only going to plate the bottom about 3 inches on ea side...youll see
Hey Dan. Did you have a crush sleve in that 3rd when you broke, or were you using a solid spacer?
Does the inner part of the axle by the pumpkin ever bend or twist or is it just the very outside where it tapers??
Cool thanks for the info guys, i'm gonna try weldin somethin up on the end like that. And you say that's schedule 80 pipe just cut in half pretty much?
LOCKTUP SHOULD HAVE HIS OWN DISCOVERY CHANNEL SHOW!!
Knock on wood I'm still running the same 4:88's for 5 years now. And I'm not easy on my junk. Be careful when your doing all that welding to the housing. You can warp it. When I was building my housings I was amazed on how much they moved while I was welding.Jason
Nice work. How did you mount the springs so they don't fall out?
Started by Jared Engine
Started by dune_it86 Project Research and Build-Ups
Started by Last Toyota Pickup/4Runner Tech 1979-95
Started by drayday55 Toyota Pickup/4Runner Tech 1979-95
Started by 86moneypit Toyota Pickup/4Runner Tech 1979-95
