Hi guys, I got a compressor out of another toyota that has the same compressor, but I found that the manifold that the hoses bolt into are different. If someone has a bad compressor that they can pull it off of, that would help me out a lot!
Also, I need a ECT sensor and cold start injector timer switch for the 89+ pickup. These use the push plugs instead of the older spring clips. Both of these are located on the front of the engine right under the TPS. Let me know. Thanks.
