I have this thing about not fixing something until it is broke
there is a good reason for preventative mantinance but when it comes to high dollar parts like transfer cases
I would wait and see if it gives you a problem. you can pull just the transfercase if needed to fix it later if it does give you a problem
while you have it apart it is a good thing to check for leaky seals and stuff also put in a new throw out bearing and pilot bearing
but I wouldn't worry about replacing the case until needed if I were you. but if it has leaky seals in it replace those and throw it back in there
they are usually good for a lot of miles. mine had 250,000 on it when I pulled it and it was still in good shape with no noises. I just went to a dual box set up and 23 spline cases
