Rear window, tinted (dark, and not the cheeseball tinting) everything good on it and in great condition.
$50
3" body lift. Bolts are there, just missing the radiator dropping brackets (might have them but dont count on it)
$40
Passenger front Fender, good condition, couple small dents and also dented in the bottom where tire self clearanced itself, still has Toyota 4WD on the side
$35
Pass door in great condition, needs new inside door panels, wingwindow and glass still good, have keys for both doors.
Driver door in alright condition, idiot friend kicked it in but can be poped out pretty easily, needs new door panel, missing window crank, glass and wing window there and in good condition.
$80 obo
P/S pump and bracket. Also reservoir and lines (I think the lines might be cracked though) does not come with hardware.
$25
Early Style Cylinder head, missing cam, have the rocker arm assembly, also has intake manifold and carb, all that stuff could use a good cleaning to be operable again.
$50
Toyota rear 51" leaf springs. 3 leaf pack, stock, missing center pin, the vulcanized stock bushings have been burned out with cutting torch
$30
First gen air conditioning. compressor, pump, dryer lines and evaporator included. Condensor is kind of coming apart but still good to use. (if you want pics let me know) bought for $100 last year
$80
All parts are located in Chico, CA 95973. If you would like it you can figure out the shipping costs with the zipcode or arrange way to pick up. If you are interested in anything please reply here or PM me.
If I have more stuff I will add it later.
