Author Topic: toy axle swap Q  (Read 3567 times)
GreyZuk
  • Turtle Points: -1
  • Member since Oct '06
toy axle swap Q
« on: Sep 29, 2007, 10:39:53 PM »
So I get it that the stock sami rear diff is offset by about 4-5 inches to the right which is why so may people run CV driveshafts in the rear when they switch to toyota axles which are centered. But since I will need to weld on new spring perches anyway, couldn't I just offset both of them 3" to the right and run a 3" spacer on one side so the wheelbase would still be equal on both sides but it would get the diff closer to center which should help eliminate some of the d-shaft vibes. Sure there is a little bit of extra leverage on the wheel bearings on that side but samis are really light and a lot of fullsize yotas are running 3" spacers anyway
Please share your opinions
Joe S.
  • Male Posts: 252
  • Member since Nov '06
  • need a zuki...
Re: toy axle swap Q
« Reply #1 on: Oct 01, 2007, 10:04:17 PM »
i think you would be better off buying an offset rear housing that either Sky or Trail Tough sells... id be afraid to do that.
Zuks are more than a hobby...
twistedtoy92
  • Turtle Points: -255
  • Male Posts: 3,781
  • Member since Dec '06
  • NFM Customs
Re: toy axle swap Q
« Reply #2 on: Oct 01, 2007, 10:09:02 PM »
dont put a spacer on only one side, bad idea
46&2
  • Hillbilly
  • Turtle Points: 8
  • Male Posts: 4,834
  • Member since Dec '05
  • California livin'
Re: toy axle swap Q
« Reply #3 on: Oct 01, 2007, 10:58:40 PM »
X2
Those diamond axles are somewhat affordable and you can design them to whatever specs you need. I would check into something like that, safer is better.
http://www.diamondaxle.com/
GreyZuk [OP]
  • Turtle Points: -1
Re: toy axle swap Q
« Reply #4 on: Oct 02, 2007, 08:02:53 AM »
I hadn't even looked into those, I was under the impression that they were super expensive
MiniSimp
  • Outdoor Enthusiast
  • Male Posts: 5,120
  • Member since Jan '05
  • SimpsonBrothers.net
Joe S.
  • Male Posts: 252
  • need a zuki...
Re: toy axle swap Q
« Reply #6 on: Oct 02, 2007, 02:08:38 PM »
www.trailtough.com
Modified Toyota rear end housing gets 3" of the offset back to help with vibration and transfer case breakage issues associated with the centered Toyota axle. Comes complete with perches and shock mounts, powder coated and ready to install. Requires use of shortened axle shaft.
Housing - Item #TRE-400 Price $275.00
Axle shaft - Item #TRA-400 Price $125.00
www.sky-manufacturing.com
Toyota offset Differentials for Suzuki Samurai's. Being built on a custom basis currently, we will soon be building fabricated housings available in various widths. Currently only available in the 56.5 width.
Sky Manufacturing needs cores! If you have a Toyota 79-85 rear axle housing and shaft, we will offer you $75 in store credit. Splinable axle shafts, these are the shafts that neck up after the splines, wide axle or standard, $25 shaft in store credit.
46&2
  • Hillbilly
  • Turtle Points: 8
  • Male Posts: 4,834
  • California livin'
Re: toy axle swap Q
« Reply #7 on: Oct 02, 2007, 05:13:06 PM »
AHh didnt know about those. I would go with Joe's suggestion as the diamond axles are about twice that much
busmup808
  • Member since Jul '07
  • busmup all day all night
    • BusmUp808
Re: toy axle swap Q
« Reply #8 on: Mar 12, 2008, 05:38:44 PM »
You could use a later FJ rear end. My friend put that on his 88 tin top. The front was and 85 hilux axle and the rear was from the FJ. The year i really don't know. Axle was off 76 FJ40
Last post Jan 02, 2004, 03:51:35 PM
by jvministries
Last post Mar 25, 2008, 08:49:59 AM
by OOPS
Last post Apr 13, 2009, 11:59:52 AM
by Rocksurfer
Last post Mar 14, 2009, 12:54:09 PM
by bgiffie
Last post May 11, 2009, 06:01:38 AM
by Gittinit
