84 mini vs 87ifs 4 runner
Started by jfksdfj60, May 09, 2004, 09:02:40 PM
jfksdfj60
Hello
I have an 84 mini truck all stock, 22r carb 5 sp solid axle.  I also have an 87 4 runner 22re 5 sp ifs.  The engine in the runner is shot as is the body.  I would like to know what is interchangeable between the two.
Thank you in advance.
John
In a word, everything.  Well everything except the front end but who would do that anyway??  If you want to use the re out of the runner just swap the whole harness into the truck.  Simple job just time consuming.  Youd also have to clean a few wires out of the runner harness, such as the rear window motor wires and a few other runner only options but its real easy overall.
Paul_Elbisser
 Well sort of. The 87 has a w56 trans. Stronger than what is in the carb truck, but it is a forward shift. You may need to cut new holes in the floor if you swap that in. The fuel tank on the 87 has an electric pump inside. Good if you plan to put EFI in the mini. Not sure if it mounts the same way. The rear axle on the IFS is wider and the breaks are bigger. The rear driveshaft should have a larger bolt patern than the older mini
You could also use the IFS front brake calipers on the solid axle, if you swap to vented rotors from Land Cruiser. IFS steering box for crossover steering. use the T cases for dual case setup. Posibly the seats. Does the 4runner have a clinometer? Don't let that go, unless it's to me!!
What did you want to do? are you just trying to figure out what to keep before you scrap it?
Paul Elbisser
PastTLCA Eastern Rep,
Pres. Rice on the Rocks
One of Those Guys
kyle_22r
you've got it backwards, the '85's G52 tranny is forward shift, the W56 is top shift
SWAMPER
lowgeared
If I were to do it all over agin, I would have built up the 4runner rather than the pickup.  The pickup looks cool as hell stealth black and bobbed, but the runner gives you more room.  I am a tool/spare parts freak on the trail and everyone usually comes to me for help.  We go on a lot of tent and tarp/run what ya brung runs and it would be real nice to carry everything inside.
SWAMPER
brainlessfool
runners that can get out of the mall parking lot are cool!  :laugh: :hahaha: :laugh: :hahaha:  :psss:  :_order:  :wave:
SWAMPER
Brainless was that directed at me?  :mad:
brainlessfool
SWAMPER
I shall slap you  :slap: and hear me by the end of today (if i can figure out how to work the scanner at work) Ill be posting pic's of swamper offroading and no more :beer: offerings from me brainless you disapoint me  :slap:
84runner
Don't sweat the small stuff and just put the motor out of the mini in the runner and SAS it then call it good  :thumbs:
SWAMPER
