Author Topic: 22re knocking? Where to start  (Read 8796 times)
yoter
  • Member since Jan '06
« on: Sep 17, 2007, 07:46:47 PM »
Well I am picking up another 89 4x4 reg cab pretty cheap this weekend. Great body, 5spd, interiors rough, 3" body lift, 33" gumbo mudders on 15x10 aluminum wheels, Broke right axle (IFS) for $600.And it does come with a title. Its a pretty good deal in my opinion. Just got back from looking at it. The only thing I noticed is the 22re is making a loud (very loud) knocking at idle, and gets louder and faster with gas. Im no toyota moter tech, so I was just curious were to start looking. Someone told him it might be a wrist pin, but I have no idea :headscratch:
Shamb
  • Raisin in the making..
  • Turtle Points: 133
  • Male Posts: 3,414
  • Member since Oct '04
  • Proud Parent
Re: 22re knocking? Where to start
« Reply #1 on: Sep 17, 2007, 08:18:04 PM »
rod knock?
or valves need adjustment?
did you check the fluids when you looked at it?
nvtoyin21
  • Male Posts: 202
  • Member since Aug '07
    • Buy me a drink
« Reply #2 on: Sep 18, 2007, 03:06:39 PM »
I would think bottom end. I would say a rod. either end of it, wrist or connecting rod. Also, may be a valve smackin the piston. Any way you look at it, its bad. Does your friend still run it around like that or does it just sit, might ask how long its been rattlin. Also, drain the oil, look for pretty glitter oil. that will tell you if it is bottom end is donezo!
yoter [OP]
« Reply #3 on: Sep 18, 2007, 04:06:49 PM »
Ok, the oil was on the full mark, (didnt check for shavings) The guy drove it bout 8 miles from his house to a shop, and it has been parked since. May be better to find another 22re to drop in.
nvtoyin21
  • Male Posts: 202
    • Buy me a drink
« Reply #4 on: Sep 18, 2007, 04:25:00 PM »
Ya that would your best bet or if you feel like tackling that engine, you could tear into that engine and find the problem and fix it or rebuild it since you would have her apart. If your not into doin it the hard way then ya, find a fresh engine and stick ur in.
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
« Reply #5 on: Jan 13, 2008, 06:59:00 PM »
sounds like a  rod knock
rebuild time
86bobbedtoy
  • Turtle Points: 686
  • Male Posts: 3,938
  • Member since Oct '06
« Reply #6 on: Jan 13, 2008, 07:23:00 PM »
souds like a rod knock, pull them out and check the crank for scaring.
weirdtimes_7
  • Male Posts: 1,032
  • Member since Nov '06
« Reply #7 on: Jan 14, 2008, 03:38:39 AM »
When you find out what it was, then you should update as to what you found... we all like to hear when something get's fixed
military_stang
:respect:
Stew Padidiot
  • Turtle Points: -2
  • Member since Nov '07
« Reply #8 on: Feb 06, 2008, 07:05:05 PM »
I HAD A TOYOTA 22RE THAT HAD A BAD KNOCK IN IT AND IT DIDNT SEEM TO BOTHER THE TRUCK AS FAR AS POWER. I BOUGHT IT WITH THE KNOCK, COME TO FIND IT WASNT A ROD KNOCK OR NOTHING MAJOR THE MOTOR WAS TIRED AND HAD BAD PISTON SLAP, A WAY TO CHECK FOR PISTON SLAP IS START THE VEHICLE REV THE ENGINE TO ABOUT A GRAND OR SO HOLD THE BRAKE AND EASE OFF ON CLUTCH AND IF THE THE NOISE STARTS TO FAID AWAY THEN U PROLLY HAVE PISTON SLAP, AND I WOULD SAY RUN IT TO DEATH IF U DONT GOT THE MONEY TO REBUILD IT
DanS
  • Turtle Points: 5
  • Male Posts: 434
  • Member since May '06
« Reply #9 on: Feb 06, 2008, 07:10:43 PM »
military_stang
:respect:
X2 I'd be curious to know ?
Wow, been looking at my 4Runner rust away too long, need some inspiration and here I will find it...!
85 Toyota 4Runner, solid axle, 22Re, original paint and graphics and not a straight panel to be found!
93tonkatoy
  • Turtle Points: 5
  • Male Posts: 463
  • Member since Jul '07
  • drive it till it breaks! then break out the tools.
« Reply #10 on: Feb 06, 2008, 09:17:46 PM »
If it is a connecting rod bearing, you will need to pull the crank and measure the rod journals with a micrometer. If they are not up to spec, and are galled, you will need to have them ground and polished, and will have to get oversize bearings. The other option would be to find a donor engine with a bad top end, and either swap the good parts in, or swap the block entirely. I just replaced the crank in my 22r-e because of a spun bearing. I had an old engine to get the crank out of, and it was in very good shape, so it went right in. But, I had to pull the engine to swap it out.
SAVE TELLICO post 491
bad luck
  • Turtle Points: 897
  • Male Posts: 271
  • Member since Sep '07
  • sas!
« Reply #11 on: Feb 07, 2008, 06:55:01 AM »
my old motor had the same sound but the thrust washers had 1/2inch movement and the rod bearings were .75
Last post Feb 22, 2003, 04:07:53 AM
by BigMike
22RE won't start
Last post Sep 27, 2005, 06:36:54 AM
by RHG
Last post Feb 01, 2006, 11:08:04 AM
by toymech
Last post Oct 17, 2006, 02:07:02 PM
by miks85yota
Last post Mar 20, 2007, 08:46:39 AM
by fordh8r
