0 Members and 11 Guests are viewing this topic.
you can keep your ifs pump, but you need to convert to hysteer, there is no other way around it
just use the stock solid axle steering until you can afford hysteer
could you find a used high steer from the junk yard
You would have to make a drag link and connect to the stock tie rod. Don't think it would be to difficult. Its the cheap easy way. Its hard to see but that whats Brian did in his F-toy.
one of the guys i wheel with modified his steering arm on the passengers side to where he could use a drag link above the leaf spring connecting to the stok ifs box and then to the passenger side steering arm keeping the existing tie rod below the leaf spring. it was actually pretty simple and was just a matter of cutting up another steering arm he had laying around and welding it up to the passengers side arm. ill look for pictures...
Started by Bones Parts For Sale
Started by burl4x4 Parts Wanted
Started by Makohon Parts For Sale
Started by Brandon Parts For Sale
Started by slickrock1 Toyota Land Cruiser Tech
