which tire combo do I need
Started by 1983 yota, August 31, 2007, 07:40:11 PM
1983 yota
I have an 83 4x4 and want to do at least a 5" marlin kit. what size tires is the best for that lift??  37x12.5   or  37x14.5
Shoyrtt
Quote from: 1983 yota on August 31, 2007, 07:40:11 PM
There really isn't an answer for your question unless you give us more information. Where to you plan to wheel your 83? Rocks, mud, trails? IMO the 5" lift is too tall for a 1st gen. The 3" or 4" lift with some trimming will keep your center of gravity nice and low and better for most applications. Tell us more about what you are looking to do and you will get more opinions on your tire choice. ;)
And finally, post a picture of your 83 :worthless:
http://www.sharetrails.org/
fatt_matt
#2
i'd go with the 12.5  unless your in pismo constantly. They're better mpg. They're ussually cheaper. and 12.5 is still pretty wide, it's just not the widest.
Quote from: Shoyrtt on August 31, 2007, 10:40:36 PM
...IMO the 5" lift is too tall for a 1st gen. The 3" or 4" lift with some trimming will keep your center of gravity nice and low and better for most applications...
X2.. 5" is too tall.  i'd suggest the 4" because even thought there is trimming, it's not too bad but either the 3" or 4" could work.
and picture picture picture!  the 3" would be a hack fest.. if your into that stuff
Jeep
1983 yota
I plan on going through trails but rocks mostly. I dont want to send any pictures yet because I dont want to get laughed at. How big of tires with the 4" for crawlin????
1983 yota
Does anyone have pictures of this truck with a 4" lift???  5"????
red
get laughed at? have you seen how ugly some of the rigs are here? my zebra 87 4runner for example. you will need 15 posts before you can post pics, but if you provide a link (photobucket.com for example) then we could see the pics. most people here are in the process of building their rig, some are completed and bad ass, some mildy built, some stock, and some that need quite alot of work. we're not like pirate over here, we dont treat people like crud because of what they have or the questions they ask.
on that body style i know a 35 will fit with no trimming and a 4" lift, larger will require some trimming.
read and comment :whip:
USAF EOD tech
1983 yota
Shoyrtt
Quote from: 1983 yota on September 01, 2007, 03:11:56 PM
Trimming of just the fenders or??
So here is Marlin's truck on 37s and 4" springs. It looks like he trimmed and tubbed the front fenderwells (very common) and also trimmed the rear fender openings. As said above, don't worry about posting pictures of your 83 here.  :therethere:
Shoyrtt
If you are in the rocks you want a tall tire to give your difs the most clearance as possible. The 12.5 wide tire is taller than the 14.5. A good "bang for your buck" tire that a lot of people run is the 36X12.5X15 Irok on an 8x15" wheel.  :twocents:
