Hubs
Started by Dixieland87Toyo, August 29, 2007, 04:46:38 PM
Dixieland87Toyo
Need the answer asap. Is there a Aisin Hub Rebuild Kit and if there is where can I purchase it
Duffil
what exactly do you need? MC has some stuff here: http://www.marlincrawler.com/htm/axles.htm
Dixieland87Toyo
So pretty much all you can do to a hub is replace the Hub Outer Dial Gasket
Duffil
unless you break something, like a gear.
usually a clean and grease job is all they need.
yotakid88
if you whant to make them stronger get boby longs cromo hub gears
got low range
95/91 pickup, 3in tuff country lif and a bunch of marlins stuff.
