Author Topic: 79 on fullwidth axles  (Read 2337 times)
89toy
  • Turtle Points: 2
  • Male Posts: 1,003
  • Member since Apr '07
« on: Aug 27, 2007, 11:06:21 AM »
I have a 79 that is anything but pretty, but it does relatively well in the rocks for only having t-case gears.  I am wondering the benefits and drawbacks of going fullwidth axles?  Also, what axle would be best and even stronger than a longfield toy?  I have heard the D-60's are good, but what years and out of what kind of truck?  Can I still run my toy setup (t-case) if I just re-work the d-shafts (yokes)?  Thanks for any advice.
He who dies with the most toys...still dies.
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
Re: 79 on fullwidth axles
« Reply #1 on: Aug 27, 2007, 12:05:09 PM »
yes  you can keep the toy tcase,  no biggy
i would go dana 60 front gm 14 bolt in rear
Lizard_lips
  • Turtle Points: 12
  • Male Posts: 1,076
  • Member since Aug '02
  • Marlin Crawler
« Reply #2 on: Aug 27, 2007, 12:17:27 PM »
I would also go 60 & 14bolt I've wheeled with fullwidths on my old toy for about 4 years and have built a few more with fullwidth axles. Just get some hysteer arms and make a drag link and tierod. you can also get a toyota flange for the dana 60 and the 14 bolt from high angle driveline.
The statistic on sanity is that One in every four is insane, Think of your three best friends if they're ok then its you.
bigarms23
  • Turtle Points: 111
  • Male Posts: 2,897
  • Member since Jun '07
« Reply #3 on: Aug 27, 2007, 12:58:04 PM »
I am running d60 f&r with dual toyota cases and yota driveshafts with yota springs I got my axles off my buddies 82 one ton chevy truck they are alot more stronger than my other 4runner with birfields. The only draw back is the added amount of weight but i can still drive my on the freeway at 95 mph
trail mate
  • Male Posts: 19
« Reply #4 on: Aug 27, 2007, 01:42:07 PM »
mid 70's ford 3\4 ton trucks have d60 front and rear. :thumbs:
89toy [OP]
  • Turtle Points: 2
  • Male Posts: 1,003
« Reply #5 on: Aug 27, 2007, 02:11:47 PM »
any big drawbacks of having fullwidth axles?  I have a buddy with d-44 axles on his samari and it works really well.  I am just trying to get a good idea of what problems I might have or better yet, the good that will come from them (besides being stronger with a d60).  How hard is it to make hysteer for these axles...or is there a kit (that doesn't cost mucho $$)?  Not too worried about the extra weight, this is a trail only rig and probably won't see much over 20mph.
snowplow
  • Male Posts: 257
  • Member since Aug '06
  • smoke tires not drugs
« Reply #6 on: Aug 29, 2007, 05:20:05 PM »
BIG TIRES + minimal lift =  :thumbs:
plus you'll have more unsprung weight, which sucks high speed handling, but is cool for you cause it makes more droop.
and your much wider wheel base will have more leverage on your springs which would make more travel as well. That would be a good setup for a buggy leaf...
...and remember, burn tires-not drugs!  :disturbed:
fatt_matt
  • Turtle Points: -3
  • Male Posts: 545
  • Member since Mar '07
  • jeeps and toys can get along
« Reply #7 on: Aug 30, 2007, 04:29:53 PM »
:cool: nah...
Jeep
89toy [OP]
  • Turtle Points: 2
  • Male Posts: 1,003
« Reply #8 on: Aug 31, 2007, 09:00:07 AM »
anybody happen to know what a 14 bolt goes for...and a D60?  Just trying to make sure...I have seen a few and want to know a price that is fair so I don't end up paying too much for em'.
wombat
  • Turtle Points: -2
  • Member since Jan '07
« Reply #9 on: Aug 31, 2007, 10:55:24 AM »
I have seen 14 polts go as cheap as 75 bucks.. I wouldn't pay no more then 150 for a 14 bolt... 60's on the other hand are extremly expensive... if you can fin a GM 60 front, they seem to be the cheaper version, but I believe they have a LP
red
  • Turtle Points: 199
  • Male Posts: 1,616
  • Member since Jan '05
  • irish redhead texan, interesting combo
« Reply #10 on: Aug 31, 2007, 11:05:54 AM »
there are 3 versions of the 14 bolt from gm.
9.5" 3/4 ton semi-floater. little more expensive to get a locker for and not a full floater (but highly unlikely to break still). offered in both 6 lug and 8 lug.
10.5" ring gear 1 ton full floater. much stronger but also has much less ground clearance (housing can be trimmed). cheaper to get a locker for, and if you should break an axle shaft the wheel wont go anywhere (unlike a semi-floater). comes in both single wheel and dually options, but the hubs are interchangable.
11.5" ring gear 1 ton full floater. this comes behind the duramax and is the strongest.
read and comment :whip:
USAF EOD tech
iNfErNaL
  • El Presidente
  • Turtle Points: 109
  • Male Posts: 7,509
  • Member since Aug '04
« Reply #11 on: Aug 31, 2007, 11:09:27 AM »
Dude,don't run full width 1 tons!!!...Full width 1 tons are for dudes that are trying to compensate for something  :yupyup: .
WWW.GLOBALOFFROADSUPPLY.COM
Support Your Local Brawlers
 www.RockBrawlers.com
 www.offroadtruckshow.com
bigarms23
  • Male Posts: 2,897
« Reply #12 on: Aug 31, 2007, 11:17:11 AM »
 i have seen built one ton 60s for $600 bucks  and customs ones for around 1750
89toy [OP]
  • Turtle Points: 2
  • Male Posts: 1,003
« Reply #13 on: Aug 31, 2007, 11:34:47 AM »
   looks like I'm getting fullwidths :talkingn: um...uh...
Just trying to make sure...I found a 14 for $50 (65 if I give my bro some gas money to pic it up).  Not sure about the specs, but since it is 50 I'm goin' for it (came off of a 3/4 ton 81 chevy...2wd...I am guessing it is the 9.5 from what red said).  Now all I have to do is find a D60 that is in my price range.  Thanks for the info!!
red
  • Male Posts: 1,616
« Reply #14 on: Aug 31, 2007, 11:44:14 AM »
yep its the 9.5 (or 9.75 can remember which size it is). the 2wd is going to be slightly skinnier than a 4x4 axle but you could just run wheel spacers if need be. is it the 6 lug or 8 lug? take a picture of the differential housing, if its kinda oval shaped its the 9.5, if its irregularly shaped its the 10.5 (81 had the full floater, but the semi-floater might not have been around at that time).
USAF EOD tech
89toy [OP]
  • Turtle Points: 2
  • Male Posts: 1,003
« Reply #15 on: Aug 31, 2007, 11:57:53 AM »
I should be able to pick it up within' the month (In San Antonio...about 5-6 hours away).  I'll try and see if my brother knows how to work a digital camera and send some pics to me.   :yesnod:
red
  • Male Posts: 1,616
« Reply #16 on: Aug 31, 2007, 03:21:22 PM »
hey i'm in san antonio as well!! u up for some wheelin this weekend? pm me.
USAF EOD tech
Last post Jun 28, 2005, 11:29:06 AM
by IronClad
Last post Jan 09, 2007, 10:23:52 AM
by Lizard_lips
Last post Jul 22, 2007, 09:32:51 AM
by Lizard_lips
Last post Aug 09, 2007, 08:28:58 PM
by Lizard_lips
Last post Nov 28, 2007, 10:04:24 AM
by Lizard_lips
