Balancing is not necessary, unless you have change the weight of the rods, pistons etc.
well unless you had it blueprinted and everything put in little baggies, you changed the weight of the rods, pistons etcand ive NEVER bought a set of pistons off the shelf that were the same exact weightget real
I mean like from cast to forged. I have never balanced any of the stock rebuilds I have done and have done plenty and never have had a problem. The only engines I have balanced were ones that I went to forged pistons with different pins and the rods were changed or polished. Oh and as far as putting everything in little baggies, is there any other way.
After you balance it, blueprint it!!!!!
Started by wmflyfisher Tire and Wheel Tech
Started by surfindave General 4WD Discussion
Started by Hawk Thor Toyota Pickup/4Runner Tech 1979-95
Started by H8PVMNT « 1 2 » Engine
Started by peacesells Engine
