chevy wheels on 4runner?
Started by dardar, April 25, 2004, 09:45:03 AM
dardar
 I think I've found a good deal on some used wheels but want to make sure they'll fit. I know that chevy 6 lug pattern is the same as toyota, but is the hole in the center for the hub always the same? will I have any issues with doing this?
That all depends if the wheels are aftermarket or not.  If they are stock chevy wheels then no they wont fit.  If they are aftermarket wheels that just happened to be bolted to a chevy you might be in luck.  Most aftermarket wheels will fit no problem because they have the big centerhole so the wheels will fit all rigs with that pattern.  Good luck
WT
mr4x42u
I have never found a set of aftermaket wheels off a chevy with the 6bolt pattern not to fit a toy..I'm sure your ok..
84runner
You can always measure before you buy them  :thumbs:
DAWGTOY
Used chevy steel wheels on my toy. had to cut out the cinter with plasma torch .
thay work well but kinda heavy. :)
1983 TOY SHORT PICKUP .35/12.50S EXO CAGE HOMEMADE BED CAMO PAINT, REARS UP FRONT CHEVYS IN THE REAR, 4 WHEEL DISK, CABLE LOCKER REAR, LOCK RITE FRONT, 5.29GEARS FRONT & REAR.BOBBY LONG 30 SPLINES 9500 lb WARN WINCH. DUAL
T CASES WITH 4.7 IN THE REAR. THANKS MARLIN
