patching a tire
Started by krawler76, August 07, 2007, 01:27:39 PM
krawler76
what is  the best way to patch a torn sidewall ...
8D3TOY
Sidewall is a tough one but for a trail only rig I have seen guys patch it from the inside with the square patches used on HD truck tires.  I was told that the trick is to overlap the first one with 2-3 more going around the edge of the first one,that helps the patch hold during sidewall flex.  This is only used as a temp. solution just to get you home.
i stitched one together  with wire once  but  it  was  only a  trail/emergency fix,   im sure  it would have come apart if ran  at highway speed
Rockcrawlintoy
my buddy had a PJ dirt grip fixed. the booted it and ground it down. u cant even tell it was fixed. it was fixed at a truck tire shop.
Drew
Resident Jeep Guy
2007 JKU All Stock
ECV 7-11
79toy20r
You can do it on a sidewall.....But only would recomend it for a trail rig. If you run that at highway speeds that sidewall is going to heat up and you'll risk a blowout....I work at a tire shop and we won't even touch anything with a torn sidewall or puncture do to the liability issue
Rockcrawlintoy
yeah we had to tell them that we are only goin to use it off road. they were cool with it
Drew
Resident Jeep Guy
2007 JKU All Stock
ECV 7-11
krawler76
the torn tire is gunna be the spare.......thanx guys
lowandwide21
Quote from: 79toy20r on August 07, 2007, 11:32:47 PM
i also work at i tire shop and we are the same way
topar
I had two of my 36" Iroks sidewalls slashed when they were on DD Dodge.  I had them vulcanized by a tractor place knowing that they would only be used off road.
