'95 4Runner
Started by 72blazer, July 30, 2007, 05:02:58 PM
72blazer
Well my DD has to go. It's time to look for something bigger. This vehicle has served me well since I bought it in May '06.
Specs: 3.0 V6, Automatic Tranny, 4WD *of course*, 31x10.5/15 BFG ATs, Clear Texas Title, 174828 Miles
It has a new battery that was purchased July '06, new idler arm replaced in January '07, and a new driver side CV joint, new front brakes, new rear wheel cylinders, brake booster, & master cylinder replaced by CBC OffRoad. I also installed a Sky Manufacturing 2" coil spacer in the rear to get rid of the common "saggy butt" syndrome that plagues every 4runner. I also replaced the shocks with Rancho 5000s. The radiator was also replaced because it was having cooling issues when I bought it.
None of the body mounts are cracked & are in really good condition. It has a replacement K&N air filter and factory skidplate. Also has a Kenwood CD/MP3 player. It will also come with the full size spare with about 50 miles on it but has been sitting in my garage for the past 7 months. It also has the hitch, receiver, ball, & 4 flat to 6 round trailer adaptor. The front bumper has two tabs for lights. The driveshafts were frequently greased & there are no leaks.
What Needs Work:
1. The antenna broke off a few months after I purchased it, it had some rust at the base. I did buy a replacement but never got around to swapping it in.
2. Not a biggie, but the windshield has three small cracks.
3. It could use an alignment, vibrates at around 60 & above 80.
4. Passenger side window doesn't open, could be the motor.
5. A/C blows super cold air about 99% of the time, but the other 1% the A/C doesn't blow cold air. Could use a recharge.
6. Crack on the dash but covered.
What Will Be Included:
1. Front & Rear Toyota 8" axles, perfect for a SAS
2. Rear D60 and GM 12 bolt
3. New antenna
I'm asking 6500 OBO & need to move this thing ASAP. Located in Edinburg TX & I could deliver as far north as Laredo, Austin, or Houston.  Some partial trades are welcome *running BBC, 700R4*. If anyone wants to give it a look over or take it for a spin, let me know. & all stickers will be removed when it sells.
David
Post, PM, or Email Me.
[email protected]
more pics available here:  http://www.rgv4x4.com/forums/showthread.php?t=1667
