v6 or 4cyl ifs boxes.
Started by toyotaboy, April 20, 2004, 09:33:18 PM
toyotaboy
Is there a difference? I am selling a v6 one and someone asked me if they were the same... anyone out there know?
rest in peace Effay
01 taco needs, duals, front axle, linked rear, exo...
85 extra cab/cab for sale with efi harness. no drivetrain, will sell, make offer
Marlin
The V6 has a longer input spool housing and is a quicker raito 3 to 1 i think.
The 4 cyl has a shorter spool housing and takes 4.5 turns stop to stop.
Marlin
84runner
So does this mean that the 4 cyl box is stonger ?
toyotaboy
so will it work though? can everything be bolted up right? would you run the 4cly box or the 6cyl box?
rest in peace Effay
90TOYPU
HELLO
84runner
Brandon
Quote from: Marlin on April 20, 2004, 09:48:27 PM
Marlin
interesting, are there any markings on them to tell them apart?
Brandon Miller
RCRC, Sacramento, CA
www.RiverCityRockCrawlers.com
YotaYota
My IFS box is out of a V6, guess that means Im special :drool:
luigi
Mine came out of a V6 and is 4.5 turns lock to lock. :disturbed:
85 4 Runner
22RE Auto to 5speed swap
Marlin Crawler Dual Ultimate Case
5.29s
Arb's front and rear
Rapidly denting away my "Mall Runner Status"
KYOTA
Mark, your Runner sure has come a long way since last year Mem. day at Moon Rocks and Bronco Canyon. See ya this year and I'm bringing my junk. :beerchug:
