Author Topic: Air Conditioning Removal  (Read 3820 times)
blyota91
  • Male Posts: 170
  • Member since Sep '04
« on: Jul 18, 2007, 02:17:08 PM »
I've got a 94 4wd 22re truck that I am taking the AC out of.  Do I have to make any changes to get it to run properly without the ac in place?  Do any other components need to be removed, currently all that is left is the evaporator in the heater box.
Thanks
Retiring the 91
Rebuilding the 94
unclejpl4x4
  • Turtle Points: 348
  • Male Posts: 3,522
  • Member since Apr '05
  • Broke & rusted
    • myspace
Re: Air Conditioning Removal
« Reply #1 on: Jul 18, 2007, 02:32:12 PM »
i would not think so ................. i plan on doing this my self
blyota91 [OP]
  • Male Posts: 170
« Reply #2 on: Jul 18, 2007, 02:57:06 PM »
I didn't think so.  My 91 without AC has fewer VSV on the valve cover and less vacuum lines as well.  I'm assuming that it must idle up some with the ac on due to the load and I wasn't sure if this would have to be compensated for.
Retiring the 91
Rebuilding the 94
unclejpl4x4
  • Male Posts: 3,522
  • Broke & rusted
    • myspace
« Reply #3 on: Jul 18, 2007, 03:23:39 PM »
ya my truck runs bad when i hit the AC switch    no power   engine surges at idle  drive me crazy
  i just want the room for  a bigger rad / oil cooler / PS cooler      the whole rad/evep and sheet metal up front is tweak from when i hit that deer  doing 50  not alot but enoff 2 mess up holes  /clips
look at a manual and see if they show a pic of with/Wo Ac   and see whats diffrent.
even tho your 91 had less vac stuff it also is 3yrs older
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
« Reply #4 on: Jul 18, 2007, 06:39:35 PM »
just make sure  you post the parts  for sale  or  pass them on to someone that needs them
besides that  once  you remove the a/c fuse  it  shouldnt make any difference
  • Turtle Points: 1128
  • Male Posts: 9,757
  • Member since Oct '04
« Reply #5 on: Jul 18, 2007, 10:15:51 PM »
Are you lookin to sell the a/c stuff once it's off?
blyota91 [OP]
  • Male Posts: 170
« Reply #6 on: Jul 19, 2007, 04:17:11 AM »
It is already off, I hadn't thought about it but I may sell it.  I live in VT so AC isn't nearly as important as good heat  :thumbs:
Retiring the 91
Rebuilding the 94
Addicted Offroad
  • Male Posts: 236
  • Member since Jun '06
    • www.addictedoffroad.com
« Reply #7 on: Jul 19, 2007, 08:52:22 AM »
I would be interested in a full A/C setup if anyone has one. My Deluxe model didn't even come with anything.
OOPS
  • Turtle Points: 1304
  • Male Posts: 2,561
« Reply #8 on: Jul 19, 2007, 10:28:19 PM »
I pulled mine off about five years ago and have had no problems. I use the AC switch to turn on the OBA because it still activates the idle up. Last year I found a 91 in the boneyard that did not come with AC and I took the ductwork so I could remove the inside condenser. My heater seems to work better now without the condenser in there. When I installed the York, a couple of months ago it would not turn on with the AC switch. After a bit of troubleshooting I remembered that I took the amplifier thinge that was on top of the inside condenser box. After tracing the wires out and making a jumper, it works great.re.
Yota Up
  • Turtle Points: -4
  • Member since Feb '06
« Reply #9 on: Jul 20, 2007, 12:41:55 PM »
Why remove it all the way?
Just cut the belt in case you ever change your mind.
blyota91 [OP]
  • Male Posts: 170
« Reply #10 on: Jul 20, 2007, 01:49:30 PM »
All of it is removed already except the evaporator core in the heater box.  Sounds like I should be good to go as is.  I may sell the parts, gotta figure out what kind of prices things go for and what kind of shape my stuff is in.
Retiring the 91
Rebuilding the 94
unclejpl4x4
  • Male Posts: 3,522
  • Broke & rusted
    • myspace
« Reply #11 on: Jul 20, 2007, 01:57:28 PM »
well the only thing that will be no good is the dryer  go head and toss that     ( always in stall a new dryer )
DTB
  • Shoutbox Moderator
  • Turtle Points: 2
  • Male Posts: 7,110
  • Member since Nov '05
« Reply #12 on: Jul 20, 2007, 02:07:09 PM »
much better flow to the radiator..thats one reason....frees up space in the engine bay too
Quote
OOPS
  • Male Posts: 2,561
« Reply #13 on: Jul 20, 2007, 04:28:24 PM »
I removed mine because it was becoming a PITA. I had just had it serviced and recharged, the next week went to the Con and was in the Big Sluice all flexed out when there was a loud hissing sound and a cloud out the grill. Thought I broke the radiator but it turned out I cracked the condenser and the cloud was a week old load of R-12. Looked at the wife and told here, "the AC is coming out and I am turning the compressor into OBA".
Then I bought a trailer and a CTD Dodge 2500 and it has not seen the street since!!!!! :clap:
Last post Jul 05, 2007, 12:00:12 AM
by SLIVER
Last post Jul 07, 2007, 01:52:14 AM
by TRDISMO
Last post Jun 25, 2009, 08:53:40 AM
by 79coyotefrg
Last post Feb 20, 2010, 11:54:49 AM
by yotaneck13
Last post Jun 07, 2011, 11:10:42 AM
by kdub0013
