Author Topic: Oil Pump tests  (Read 1889 times)
BLACKDOG
  • 3.0 Killer
  • Turtle Points: 718
  • Male Posts: 7,644
  • Member since Aug '04
  • I used to fit
Oil Pump tests
« on: Jul 06, 2007, 05:04:32 PM »
Ok, my '91 3.0   decided to start showing lower and lower oil pressure on the guage in the dash. Guage looks kind of like this  [  I  I  ]  pressure is usually between the middle lines, toward the top end.  Recently, when I'm sitting at a light, the needle will drop down to the lower middle line, and even a little past it  :scared: under load, it'll move back up to the middle of the guage.  It'll usually fluctuate at idle a little in the past, but recently its started dropping to what I think is too low.  I'm really hoping the oil pump is not going out, because that entails tearing the front of the motor down past the timing belt.  Does anyone have an suggestions to test whether the pump is going bad, other than tearing it apart?  :dunno:  I;m gonna check a few things the FSM says to check (strainer in the pan, etc.)  but other than that, I guess I get to tear it down?  Oil is full, new oil, new filter, so that isn't the problem :thumbs:
              -Ronald Reagan
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
Re: Oil Pump tests
« Reply #1 on: Jul 06, 2007, 05:37:18 PM »
Jason   we need to find you a 3.4  and just be done with it  :headshake:
Duffil
  • *lurker*
  • Turtle Points: 138
  • Male Posts: 4,844
  • Member since Nov '04
    • PhotoBucket
Re: Oil Pump tests
« Reply #2 on: Jul 06, 2007, 05:50:12 PM »
can you put a manual (mechanical) gauge on the engine to verify whether or not the gauge is going poo?
*ROKTOY*
  • Male Posts: 1,066
  • Member since Nov '06
Re: Oil Pump tests
« Reply #3 on: Jul 06, 2007, 05:57:59 PM »
What weight oil are you using? Could be the hotter than usual weather causing the oil to thin out.
Re: Oil Pump tests
« Reply #4 on: Jul 06, 2007, 06:12:25 PM »
iagree,  in 100* weather i ALWAYS use 20-50 castrol
lilbuddy
  • Dried Fruit Warrior
  • Turtle Points: -234
  • Male Posts: 5,720
  • Hella....
Re: Oil Pump tests
« Reply #5 on: Jul 06, 2007, 06:16:03 PM »
Same here...
And I agree with the hotter weather thinning out the oil. On mine it did the same thing. It just reads really low and im even running 20-50
RIP Kyota.... you are the man
GET IT!!!
Plowking
  • Turtle Points: -75
  • Male Posts: 504
  • Member since Jan '05
  • Awesome yota
    • Buy me a drink
Re: Oil Pump tests
« Reply #6 on: Jul 06, 2007, 08:49:38 PM »
I would go for the mechanical gauge as Duffil stated to many variences in older vehicles with electrical components. Mechanical gauge is a must and most likely your savior.
Good luck
2008 Dodge Diesel  (Cummins Rule)
6.7 manual quad 8 foot bed H&S delete, banks air box
93 yota 3.0 locked up...
2004 Yamaha Raptor 660R
BLACKDOG [OP]
  • 3.0 Killer
  • Male Posts: 7,644
  • I used to fit
Re: Oil Pump tests
« Reply #7 on: Jul 07, 2007, 12:39:56 AM »
That is one of the first things I'm going to try this weekend.
:thumbs:
Same here...
x3.  I've been running 20-50 in my truck for  long time.  I drove it quite a bit today, and I'm kind of thinking that is what it is.  When I first start up, and drive, its fine, stays right in the middle, even at idle.  After the engine gets hot, it drops.  I'm betting that is exactly what it is.  If I check it with a mech guage and its good, then I'll be happy :thumbs:
thanks guys :yesnod:
              -Ronald Reagan
Wermz84
  • Rock Nerd!
  • Turtle Points: 921
  • Male Posts: 3,518
  • Member since May '05
  • Ouch My Eye!
Re: Oil Pump tests
« Reply #8 on: Sep 21, 2007, 08:15:08 AM »
**Revive**
I wish to test my pump and Guage on my 22r to see if they are working correctly.   The FSM talks about putting a pressure guage on the sending unit.  Not sure if that is mechanical or not.  I'm going to try at my local auto parts store to find one of these.  Any tips on this guys?
I like to Drive!
lilbuddy
  • Male Posts: 5,720
  • Hella....
Re: Oil Pump tests
« Reply #9 on: Sep 21, 2007, 08:59:24 AM »
**Revive**
Just go purchase a mechanical oil pressure gauge. You can pick up an Eqqus brand mechanical oil pressure gauge at Napa for about $19.99, maybe even cheaper. Make sure to also purchase an adapter for a metric fitting in case the one you buy doesnt come with one (most are standard)
GET IT!!!
MiniSimp
  • Outdoor Enthusiast
  • Male Posts: 5,120
  • SimpsonBrothers.net
Re: Oil Pump tests
« Reply #10 on: Sep 21, 2007, 09:08:03 AM »
Ok, my '91 3.0
Stop right there, I found the problem.... :greengrin:
Oil Pump
Last post Jan 20, 2005, 10:45:42 PM
by FATB0Y
Last post Jun 20, 2006, 09:32:30 AM
by Mike D
Last post Jul 20, 2007, 09:22:16 PM
by Duffil
Last post Feb 29, 2008, 10:22:05 PM
by KDXSR5
Last post May 15, 2017, 03:24:59 PM
by Gillesdetrail
