Not seein any pics What year scirocco did you snag it off?
OOPS,What tensioner is this from?This weekend I am installing my RV2 in a tight area between my engine block and frame rail, and I wanted to built a pivot bracket and an upper bracket so I could swing the compressor out light an alternator to tighten the belt, but I am tight on space. I wanted to avoid using another bearing; wanted to reduce the amount of moving parts, drag, weight, etc. But after seeing this it is soooooooo much more simple than what I was planning on doing. Spring loaded tensioner is much easier to setup-I'll head to the yard to find that compact tensioner ASAP!
Mike, That just the stock 3VZ-e belt tensioner for the A/C...i believe
Seriously though, post up your install and pics of the pump...
Started by muddinyota New Member Check-In!
Started by UNBREAKABLE Parts Wanted
Started by 4x4Danno Parts For Sale
Started by 89 toy General 4WD Discussion
Started by ToYocRawleR Parts For Sale
