check my rears up front
Started by 88runner, April 14, 2004, 11:40:32 AM
Salvo
Just go out and get a drop drag link for now untill you can afford crosover or highsteer... they are always in the for sale sections of any toyota board for cheep... Dont mess around with cuting and welding stearing components . :screwy:.. its you's and other peoples life on the line if it breaks
TigerToy
So, a drop link will work if I get those shackles?
Jared
WT, do you think if i take my front spring pack a part and the rear pack apart, do you think that if i swap all of the leafs from the rear pack not including the main leaf and put it in the front with the stock front leaf,would i get as much?
If you put all those leaves in the front pack it would lift it, but it would ride like a tank and have 0 uptravel.  Plus the steering arm would hit on the spring pack because it would be too thick.
Jared
ahhhh. i see now...  sorry bout jackin this thread...  :dunno:
88runner
completed  :eyebrow: :eyebrow:
well I think I have to lift the rear. :smack:
88 4runner v6,
5.29 with 35" tires,
Isuzu Rodeo rear disk brake,
solid axle'd
Jared
FAwkin sweet!!!  :beerchug: are those chevies???
88runner
no, they are form an 82 toyota.
88 4runner v6,
solid axle'd
You know what, ranger springs would level that out nicely.   :thumbs:
What can I say I like my suspensions!
88runner
what would I need to do to put ranger springs,(hanger relocating or anything ???)
88 4runner v6,
solid axle'd
Check out my thread "Ive been busy"  It has all the measurements that you'd need.  You WILL have to add to the pack but I am in love with these springs.  In my 84 I have added enough springs that should meke it too stiff but it is still too soft.  Damned good starting point is rangers or broncoII's.
lowgeared
I didn't add anything to my spring pack to compensate for the different perch heights.  Can't really tell by looking at it.  The front-rear springs are flexy as hell.  I have three inch blocks in the rear welded to the perches.  Makes the rear real flexy too.  I don't think anything flexes like stock springs.
81Toy4x
Quote from: lowgeared on July 13, 2004, 03:15:49 PM
So you just have stock springs in the back with a 3" lift block welded to the perch?
lowgeared
And some homemade shackles that give a little more lift.  That's it and the 35s never touch.
