Author Topic: Weber specialist in Southern California  (Read 6769 times)
TRHS1980
  • Turtle Points: 2
  • Male Posts: 234
  • Member since Apr '06
« on: Jun 26, 2007, 12:43:24 PM »
 :help: I'd like to get my Weber finally jetted right and set up correctly for my truck. I have basically no carb experience and no time to learn right now as I need to drive out to havasu in a few weeks and would like this done before then. Anyway, I was wondering if anyone out there knows someone who I can take my truck to and have this done right. I would appreciate any recommendations... Oh, and I'm in orange county. Thanks.
2007 Tacoma 4x4 6-speed on 35's
"In all affairs it's a healthy thing now and then to hang a question mark on the things you have long taken for granted."
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
Re: Weber specialist in Southern California
« Reply #1 on: Jun 26, 2007, 06:43:32 PM »
is  it running  bad rich  or  what ???  a weber is easy  to work on,  you can change the jets  without taking it off the motor
:psss:  LCEngineering  is in Lake Havasu AZ  :yesnod:
*ROKTOY*
  • Male Posts: 1,066
  • Member since Nov '06
« Reply #2 on: Jun 27, 2007, 08:11:08 AM »
x2 why do need it jetted?
TRHS1980 [OP]
  • Turtle Points: 2
  • Male Posts: 234
« Reply #3 on: Jun 27, 2007, 10:21:44 AM »
I need it jetted because those things come from the factory set up for a stock engine. To get it running right, I have to have the fuel mixture screw out more than you're supposed to. According to weber, if the screw is out more than a couple turns (i cant remember the exact number) then it needs a re-jet. The carb runs pretty good considering, but it's running rich and I know it would run better if it was jetted right. I'm also still having problems with inconsistent dieseling because I just can't seem to get this thing dialed in. I've been playing around with this thing for too long and it's time to look for outside help. I know the Weber's are easy to work on, but I also know their finicky... Lack of carb experience and finicky = :dunno:
Coyote, to get to the jets do you just need to remove the top four(?) bolts. I could just order a re-jet set from weber, but when ordering the jets you have to be able to tell them which ones you need as there are two different kinds of jets. Are the jets easy to install? Maybe if I get the right jets in this thing it will be easier to dial in.  :hammerhead:
« Reply #4 on: Jun 27, 2007, 05:40:39 PM »
theres  6 screws  on the top and  remove the tiny C clip on the choke  and move it aside
the fuel jets  are in the bottom of the fuel bowl,  a  medium size  flat screw driver  will  take them out,  but  it will have a number,  150  or 142  or 130  sometrhing like that
if  you have a 20R  you need the 130 jets
RN37DD
  • Male Posts: 742
  • Member since Apr '07
« Reply #5 on: Jun 28, 2007, 12:58:25 PM »
the weber I'm running on a 20r right now has 140 main jets and 160 air jets on both . runs smooth to 5500rpm. i had 170 and 180 air jets with 139-150 main jets and it would cook right up t 6000rpm in 3rd in a real wornout engine. but with the bigger jets the mid range suffered. check that no one has screwed with your secondary adjustment. thats why mine likes to idle high. it's feeding off the secondary low speed circut.
RN37DD
  • Male Posts: 742
« Reply #6 on: Jun 28, 2007, 01:22:06 PM »
yeah 130 and 150 main jets.. pushed the wrong button.
TRHS1980 [OP]
  • Turtle Points: 2
  • Male Posts: 234
« Reply #7 on: Jun 29, 2007, 02:45:05 PM »
I'm pretty sure that if you order a jet kit from weber that they will send you the  :_order: "correct" jets for your application. The weber is new (or a least I bought it new) so I know the jets are stock. I put a bit of work into my engine with 22r block, 20r head, bored over with bigger valves and on on... I did it once (hopefully) and I did it right. Point is that finding the right jets could be a little tricky since it's hard to go off of anyone else's setups. Anyway, anymore advice would be appreciated. I think I'll be calling weber soon to see what they can offer me.
RN37DD
  • Male Posts: 742
« Reply #8 on: Jun 30, 2007, 05:12:22 PM »
cool.... right now I'm also putting together a 20/22r and well be jetting the carb for power and economy. Lc engineering has a bunch of jet kits. I'm going to start with a 140 main jet 170 air jet primary. 142-mj -160 air jet.. Then go from there. let me know what you find out for your engine.. I'll be installing this engine July 4th if all goes well. then if it don't blow up right away, I'll start tuning.
« Reply #9 on: Jun 30, 2007, 06:48:15 PM »
20/22 hibrid,  cool,  just tell them its a 22R
is this a 38 weber or a 3236??
i have a 3236  and if i remember right, i have 142 primary fuel  and 150 secondary fuel  with a  180 primary air jet  and 185 secondary air jet
getting 18 mpg
is there anyway you can pull the top off your carb  and tell me what jets you have ??
RN37DD
  • Male Posts: 742
« Reply #10 on: Jul 01, 2007, 05:02:09 PM »
I have a 32/36 weber.. I pulled the top off and and have changed jets a few times. right now i'm running 140 main jets and 160 air jets in both primary and secondary. i have 130, 140, 150 main jets and i have 160 170 and 180 air jets, for tuning  I'm going to order some more jets but i think i'll have the motor in and running before they get here. After seeing what you've got maybe i'll try 140 fuel- 170 air primary and 150 fuel -180 air secondary to start.  then fine tune it as the new jets come in as needed.
TRHS1980 [OP]
  • Turtle Points: 2
  • Male Posts: 234
« Reply #11 on: Jul 02, 2007, 10:46:49 AM »
The carb is a 32/36. I will try to check out the jets tomorrow and let you guys know what the carb came with. Could you tell me the specs of your engine coyote? If I could find someone with a similar setup to go off then that would save me a little guess work. Just so you guys know my engine is
22R block
20R head
22R aluminium rockers
DOA C270 Cam
DOA dual valve springs
DOA pistons .040 over
1MM oversize valves
ARP bottom end
And some other things that I can't remember off the top of my head. Pretty basic stuff, someone out there must have a similar setup. :dunno: Anyway, thanks again for the help, I'll get you guys those jet specs.
« Last Edit: Jul 02, 2007, 02:36:05 PM by TRHS1980 »
« Reply #12 on: Jul 03, 2007, 06:38:50 PM »
my engine is  very  close to yours,
22R  bored .060  LCengineering stage 2 cam, .460 lift  280 duration,
i couldnt run the 20R head  do to the  .060  oversize  bore  :down:
wingdaddy
  • Turtle Points: 2
  • Member since Dec '06
« Reply #13 on: Jul 31, 2009, 01:31:18 PM »
Glen, I have been doing some very extensive upgrades on my old yota. Have put on a header with tuned exhaust. It is a stock '81 22R. Want to add cam and new carb, what do you suggest? :bowdown: :dunno:
« Reply #14 on: Aug 02, 2009, 11:36:26 AM »
sent you a pm :thumbs:
acerbis
  • Male Posts: 102
  • Member since Dec '07
« Reply #15 on: Aug 04, 2009, 10:12:18 AM »
Does anyone have expierance with the 34/34? Since we are on the subject of carbs what do you guys think about the intake noise when adding a weber?
you'll never be younger then you are today
« Reply #16 on: Aug 04, 2009, 11:21:24 AM »
you mean the sound of more air/fuel mixture being sucked into the engine??   I love it :burnout:
Last post Jul 07, 2004, 09:11:12 PM
by 84runner
Last post Oct 19, 2005, 07:24:56 PM
by Loosekannon
Last post Feb 21, 2006, 08:27:59 AM
by alwaysbroken
Last post Jul 08, 2007, 01:41:09 AM
by Tool Pimp
Last post Jul 27, 2021, 01:00:58 PM
by 90 sa-yota
