Author Topic: E locker wanted for 1st gen axle  (Read 1914 times)
rscalmo
  • Trade Count: (0)
  • Male Posts: 118
  • Member since Feb '07
« on: Jun 14, 2007, 12:58:40 AM »
anybody got an E locker for a 1st gen axle? preferably geared at 4.88??
rebuilt 22R, downey header long tubes, 2.5" exhaust, 4 inch marlin lift with 3 inch shackles, detriot locker, 4.88's on 33's.marlin cross over steering and fror crossmember, power steering conversion, chromoly 30 spline bobby longs, 86+ wider rear axle, 12 inch 5150's all around, fully gusseted with armor...soon to be sitting on 35 bfg MT with an all pro roll cage and rock lights!
  • Trade Count: (0)
  • Turtle Points: 2872
  • Male Posts: 8,707
  • Member since Sep '05
Re: E locker wanted for 1st gen axle
« Reply #1 on: Jun 14, 2007, 11:08:14 AM »
an elocker isnt going to fit into a 1st gen axle without modifying the axle housing itself
dieselsmoke
  • Trade Count: (0)
  • Turtle Points: -40
  • Male Posts: 134
  • Member since Nov '05
« Reply #2 on: Jun 14, 2007, 10:44:56 PM »
Your not going to find a 4:88 either, check on ebay I got both of mine off ebay. the mods to the housings look easy enough, it won't work on a 7.5" axle, has to be 8" Also the 86 and later rear axles are wider.
I have a pair going in my heap with Yukon 4:88's and solid pinion spacers
rscalmo [OP]
  • Trade Count: (0)
  • Male Posts: 118
« Reply #3 on: Jun 16, 2007, 05:07:16 PM »
i saw what has to be done for the high pinion e locker on this site...looks manageable enough. will my current 4.88s work on the e locker 3rd member too? man they are expensive! 900 bucks from marlin! wow...my axle is an 8inch
dieselsmoke
  • Trade Count: (0)
  • Male Posts: 134
« Reply #4 on: Jun 17, 2007, 08:33:31 PM »
no you have to use v6 gears and the master kit to install them is different also, I have the part numbers for the yukon parts the ring and pinion is
yg tv6-488 and the install kit is yk tacoma-loc I got mine from performance off road center p.o.r.c. they sell them on ebay I paid 700.00 for 2 of each including shipping, cheepest I found for yukon parts thier are others out there that cost less but are not as good. I also got the solid pinion spacers from marlin, I like the set it and forget it
that price was for standard rotation gears, the high pinion e-locker can use reverse rotation gears but they cost more.
« Last Edit: Jun 17, 2007, 08:38:35 PM by dieselsmoke »
rscalmo [OP]
  • Trade Count: (0)
  • Male Posts: 118
« Reply #5 on: Jun 17, 2007, 11:11:39 PM »
sounds like one expensive deal! can a detriot be used up front instead?? much cheaper and easier...drawbacks?
dieselsmoke
  • Trade Count: (0)
  • Male Posts: 134
« Reply #6 on: Jun 19, 2007, 07:16:06 AM »
the nice thing about the selectable locker is the ability to unlock it for turning. The detroit will bind in turns and what you will find is you will go straight instead of turning, especially while going down hill, and that is not a good thing. I will have 2 buttons on my dash that will let me lock or unlock at will, also since my rig will be a daily driver when they are unlocked I will have a regular open diff. then when they are locked I will have 2 spools. As for the cost marlin sells e-lockers with 4:88's and solid pinion spacers for 1300.00 each when I'm done with mine I will have 1300.00 in the pair
toysfreak
  • Trade Count: (+4)
  • Turtle Points: 227
  • Male Posts: 632
  • Member since Sep '03
  • I Love My Marlin Crawler!
« Reply #7 on: Jun 28, 2007, 07:29:17 PM »
I have a elocker diff that the ring gear is no good on.  Needs gears and install kit.  Will let it go for $350.00 with the elocker motor.  Can ship too.  In Burbank  CA  91510   It weighs 65 lbs.
95 4 runner. 4 cyl dual ultimate w. R150.  V6 rear w spool.  New Chevy springs on 12" extended frame.      Front.  SAS w chromoly shafts.  And spartan    In frazier park ca 93225
rscalmo [OP]
  • Trade Count: (0)
  • Male Posts: 118
« Reply #8 on: Jul 01, 2007, 10:46:20 PM »
its the high pinion one right? if it is i will take it. it will have to wait till next week tho im going out of town tomorrow morning.
rscalmo [OP]
  • Trade Count: (0)
  • Male Posts: 118
« Reply #9 on: Jul 09, 2007, 01:08:30 PM »
pm'd ya toysfreak
Last post Feb 19, 2004, 09:19:37 PM
by Thumper
Last post Dec 19, 2004, 01:54:41 PM
by rubiconrunner
Last post Mar 02, 2006, 11:06:34 PM
by toysfreak
Last post Mar 06, 2011, 07:09:15 PM
by Troy
Last post Nov 04, 2011, 09:26:23 AM
by crazykooter
