army noob from washington
Started by baconator, June 02, 2007, 08:23:00 PM
red
ah ur truck reminds me of my old 81 gmc. you can easily put a cummins 12 valve in there, i know a few people that have done that swap into that body style gm. do you want a stick shift or an auto? if you go auto 4l80E with a stand alone computer would be your best option, unless you have some money lying around and want to go with an allison. if you go stick the nv4500 is a direct bolt on (5 speed stick from both dodge and gm), or the nv 5600 if you want a 6 speed (from dodge).
read and comment :whip:
USAF EOD tech
baconator
Quote from: red on September 02, 2007, 08:49:54 PM
i would love to put a 4500 or 5600 behind the future cummins but thats ALOT of cash.  i have seen junkyard 4L80Es for fairly cheap.  a good rebuild and it should handle all the power i think i want.  i might get a true diesel drag tranny too.
check out the first project from Born Crazy Customs
Quote from: MrsWillyMammoth
OK so we got the thick bacon... but RK can't find the salami... and Deans wife has the cheese...
baconator
ok so heres the basic idea for my monster rig...
this cab
on this frame
with these tires (52x18R20)
on some 2 1/2 ton rockwells
yes... its going to be big.  hopefully the wheel wells are big enuf i can keep the COG fairly low
88toyota
its gonna look nice when its all done
red
Quote from: baconator on September 03, 2007, 01:52:51 AM
which drag tranny are you talking about? most the guys i know that do sled pulls or drag race use either the 6 speed stick or the allison auto.
should be able to get an nv4500 for 1500-2000 bucks.
how much power are you looking to make? if its not too extreme you could go with a cummins 4bt (3.9L). has the same bolt pattern and is just as reliable as the 6bt, not difficult to make 400 ft/lbs of torque from it.
USAF EOD tech
baconator
Quote from: red on September 03, 2007, 11:14:14 AM
knowing me and my desires for something crazy i will be wanting a 6bt.  i was kinda hoping for 700+ ft/lb.  this project wont be for a while so i will prolly save up for the nv4500 and do it how i want it
