1985 factory wheel spacers
Started by lowgeared, April 04, 2004, 02:30:01 PM
lowgeared
On my 85 4runner and 85 parts pickup there are factory wheel spacers on the front.  Are these to clear the brake caliper??  There aren't any on my 84??
Marlin
Factory wheel spacers?  Do they say Toyota on them?  You may have a rare collectors item.
Have never heard of spacers made by the factory :dunno:
Yes, the spacers are designed to clear the calipers.
Marlin
lowgeared
They may not be from the "factory".  They are stock though.  This is the third set I have seen.  The don't say anything on them and they are a little more than a 1/4 inch thick.
