20r and 22r exhaust valves.
Started by RN37DD, May 20, 2007, 08:22:06 AM
RN37DD
 I just checked the exhaust valves for my 20/22r motor and it looks like they're 22r valves. 112.4mm short and the valve head is 36.9 mm. I though 20r exhaust valves were 113.5mm long. Question well I have a problem running these valves? Anyone know how long the exhaust valves are that LCengineering has for the 20r? when you look it up it just says 20/22r. The machine shop here says the exhaust valves are the same.. I'm running old 22r rockers too. Anything Else I should check??
nope , looks like your good to go
RN37DD
yeah i think i'm going to run them. valve springs might be a little tighter but the cam lift is only .430 max and it might even help at high RPM..
actually  it does help  keep them tight,  make sure  your  valve seats match the valve,  the 20r seats  must be removed  and the 22r seats  installed
gotta have a COMPETENT  machine shop
btw  the cam i have is a .460 lift  :burnout:
RN37DD
Too much $$ to put in the new valve seats at this time. going to order some over sized valve 20r from engnbldr.. That way I'll upgrade the intakes too.  Think i'll try their cam also.
