'83 Cummins
Started by Geius Maniacal, May 19, 2007, 08:52:15 PM
Geius Maniacal
i am curious if you guys could assemble a diff with different gears than what you have advertised on the site? i have an '83 pickup with a Cummins 4BT Diesel in it, so i have more of a need for a higher gear ratio.
please let me know!
Cam
WOW,  how heavy  is a 4BT  ???
dirtchicken
I think a 4BT weighs around 750 pounds. Definately too much for a Toy.
crazywb
  We can build it with any gear ratio available.  We will just have to order it.  Thanks  CJ  :turtle:
I'M BACK!!!!!!!
Quote from: dirtchicken on May 20, 2007, 10:49:18 AM
:yikes:
Geius Maniacal
dry weight is 570 lbs.
im in the process of rebuilding the axels to match the power, puttin in an NV4500, and upgrading the suspension to handle the weight.
so if i called you guys with whatever ratio you could build it for me? would the cost be much different than the pre-assembled diffs you guys already sell?
Thanks for the info thus far!
Cam
crazywb
If the ratio is available the cost will be the same as the comperable built unit listed on the web. On another note that is one heavy dude.  You might want to think about using toy thirds with that motor.  Don't know how much torq you will be putting down but those are only 8 inch gears in there.
Thanks  CJ
I'M BACK!!!!!!!
yea man  i'm  thinking with that much weight  you need  corp 14  and a dana60
Geius Maniacal
#8
the engine puts out around 327 ft. lbs at 1700rpms, i think those are the right numbers.
at the moment, my rear diff is gettin ripped out from the torque and it needs to be replaced. i want to build up the rear end when i put in a new diff, so what would you suggest for the diff and for the rear end?? i was plannin on using your Chromoly rears, but should i be doing something else?
BTW, here is a pic of the beast that i speak of.....
thanks a lot for the help guys
Cam
truck looks awesome... i would say to d60s... jsut to be safe.... look at the numbers, the toyota 22r put out 100 hp --- your pushing like 350% of that!!!! the 8" are very stout, but then your truck is a lot stronger than those toys were set up and heavier
Rockcrawlintoy
one tons are in order.
DRew
Resident Jeep Guy
2007 JKU All Stock
ECV 7-11
Quote from: Captain4x2 on May 24, 2007, 12:25:23 AM
327 lbs  of TORQUE   not HP,  hes  still  past the torque a 22R   would put our  with dual cases
it does  look really good,
i think we need  pics  of the engine  :yesnod:
Geius Maniacal
here are some pics of the engine, tranny, and t-case. sorry it took so long!
Cam
milla85
I bet that thing sounds RAD straight piped! like a big rig.  :)
Geius Maniacal
it does sound like a big rig! once i fix some stuff, i plan on puttin a 3in glass pack on it.
another question for you guys, i need ladder bars for this thing. where is the best place to find them? i have searched for them but havent found much at all for 1st gens.
Cam
Geius Maniacal
should this thread be moved to the projects section?
Cam
Holy Cow :o :o How much frame bracing was done near the engine mounts? Looks awesome man!
Quote from: Geius Maniacal on June 14, 2007, 01:10:47 PM
I think so :thumbs:
milla85
I bet you can really pull some jeeps out with that kind torque!  :shocking:
mima
looks good. i love diesels... but ya. i think one tons
85 yota, 4 in AP, 529s and detroits f&r, 35 in bfg mt, bed bobbed 12 in, AP winch bumper, warn 9000xdi
Geius Maniacal
what would it run me to do one tons?
Cam
Weak-Link
fullthrottle
Quote from: Geius Maniacal on June 14, 2007, 05:04:25 PM
Cam
how much you got, go's good with that questn. depends on were you live around here you could get a set for under $1000 maby as low as $600 if you spend some time looking or you could go to pull-a-part and get some off an old one ton.
SASed 94 pu- marlin crawler 4'' springs, 5.29s aussie R lockright F 30spline longs , crawler box and 37'' SSR's
Geius Maniacal
thanks for the article Weak-Link.
right now, i dont know what i will have. I just got an email this morning about some 1 tons, so we will see what happens with that.
Cam
79toy20r
Hey are you from around the spokane area? I saw that for sale on craigslist. I wanted it so bad. I love it
Geius Maniacal
yes i live up north in colbert.
im glad i got this truck, even though there are some problems with it, and since i had to buy a new truck since my other 83 was stolen.
Cam
topar
AaronB
nice find. I would like to throw a 4bt in my FJ.......Someday
Geius Maniacal
its a good engine. lots of torque and great mileage!
theres nothing like accelerating in fourth, up a hill!!!
Cam
