Autometer temp gauge install question
Started by alwayzbroken, May 12, 2007, 10:20:45 AM
alwayzbroken
Where is the best place to install the sending unit for my mechanical autometer temp gauge on my 1992 22re? Every coolant port that I can see has a sensor in it that is probably necessary. Does anybody know of any coolant port plugs that are not in use somewhere on the block that I can screw the temp sender for the gauge into? Thanks  :cool:
dirtchicken
Drill and tap the thermostat housing for the sender.
alwayzbroken
Quote from: dirtchicken on May 12, 2007, 11:55:22 AM
That sounds like a lot of work.
there  should be  a plug  in a hole  on the intake SOMEWHERE
  :headscratch:
