Author Topic: 85 4 runner engine and tranny removal question  (Read 2543 times)
intheworks
  • Male Posts: 42
  • Member since Mar '07
    • Off Road Innovations
« on: May 08, 2007, 07:56:30 AM »
i got an 85 4runner, if i remove everything from the front grill area, would i be able to remove the engine and trans. as one? through the engine bay area
Re: 85 4 runner engine and tranny removal question
« Reply #1 on: May 08, 2007, 08:12:45 AM »
engine and tranny  yes,  with tcase attached  NO
intheworks [OP]
  • Male Posts: 42
« Reply #2 on: May 08, 2007, 08:13:39 AM »
so you've done it before, is what your saying right : )
DAWGTOY
  • Turtle Points: 460
  • Male Posts: 212
  • aint too old & broke up to sit down yet
« Reply #3 on: May 08, 2007, 08:43:35 AM »
yea you can do it this way. i've had my eng/trans out repaired and
reinstalled in under 4 hours. done it many times.
this was on a 83. but an 84 should not be to different.
dawg
1983 TOY SHORT PICKUP .35/12.50S EXO CAGE HOMEMADE BED CAMO PAINT, REARS UP FRONT CHEVYS IN THE REAR, 4 WHEEL DISK, CABLE LOCKER REAR, LOCK RITE FRONT, 5.29GEARS FRONT & REAR.BOBBY LONG 30 SPLINES 9500 lb WARN WINCH. DUAL
T CASES WITH 4.7 IN THE REAR. THANKS MARLIN
4runner
  • Turtle Points: 103
  • Male Posts: 300
  • Member since Sep '03
  • I Love My Marlin Crawler!
« Reply #4 on: May 08, 2007, 06:01:48 PM »
i have removed the engine, tranny, and transfercase as one at the same time in my parts truck. just as you are thinking of doing. of coarse the crossmember will be out so the transfercase will be near dragging on the ground as the motor is coming out
built not bought 89 4runner
vortec v8, r151, dual cases
4link 1/4 elliptical
DanS
  • Male Posts: 434
  • Member since May '06
« Reply #5 on: May 08, 2007, 07:18:54 PM »
Why do you want to remove all together? I've only removed all at once by sawzalling the rad cradle in one of my parts trucks and have tried, in the beginning ,to remove all together but my chain fall would not go high enough even with 9' ceilings!
I find it easier to remove engine separatley and then drop tranny/transfer case out the bottom.
Hope it helps, DanS
Wow, been looking at my 4Runner rust away too long, need some inspiration and here I will find it...!
85 Toyota 4Runner, solid axle, 22Re, original paint and graphics and not a straight panel to be found!
Gittinit
  • throttle jockey!
  • Turtle Points: 28
  • Male Posts: 2,293
  • Member since Sep '06
« Reply #6 on: May 08, 2007, 07:35:54 PM »
I've done it but ya had better be prepared to tilt and wiggle. You will need to lift everything really high too. Its definately a pain to do it this way, but its doable.
my favorite places:
http://www.flatnasty.net/
http://www.orvpark.com/
  • Turtle Points: 2872
  • Male Posts: 8,707
« Reply #7 on: May 08, 2007, 07:39:09 PM »
im working on dropping my engine in right now, and i jsut dont see how you can even do it, trying to clear the core support....
i did pull my tranny out of the engine bay, but the engine wasnt in @ the same time, i jsut grabbed the bellhousing and started pulling
  • Male Posts: 8,707
« Reply #8 on: May 08, 2007, 07:39:42 PM »
just unbolt the tranny, and pull the engine out, its onle a few bolts, and its a lot easier to deal with
Wermz84
  • Rock Nerd!
  • Turtle Points: 921
  • Male Posts: 3,518
  • Member since May '05
  • Ouch My Eye!
« Reply #9 on: May 08, 2007, 07:42:57 PM »
Sounds like alot of work, but then again so is mating up the tranny and enging while putting it back together.  Everytime I've put it back in I always cuss wondering why i didn't try it that way.
I like to Drive!
intheworks [OP]
  • Male Posts: 42
thanks for all the help! today im gonna powerwash all the oil off the undercarage of the runner, like from the front axle to the transfercase : ) ITS BAD , even my front driveshaft...... its all covered in oil  :ack:  whats a badass degreaser i could buy to help the process? anyone know?
after all that ill remove the radiator, all wiring and other items like air box etc. and unbolt the tranny from the t-case so ill be ready to go for this weekend when my buddys show up to help and drink a few.
i got my new engine and tranny at my aswell so im hoping that i can get it done this weekend. HOPING
Wermz84
  • Rock Nerd!
  • Male Posts: 3,518
  • Ouch My Eye!
I use this and love it.  A little expensive, but it works really well.  Direct spray on, let sit a few minutes, lightly scrub with brush, and rinse.
http://www.p21s.com/products/bis_taw.html
 :qtip:
I like to Drive!
8Snaces
  • Turtle Points: 47
  • Male Posts: 396
  • Member since Apr '06
  • The krawler in H.H. over New Years.
GUNK!!! That stuff gits it all for me.
1st gen yota truck. 37x12.5x15. 5spd dual cases, chevy springs in rear, toyota rears springs in front. Long bed....the list never ends..
Dont try to shift into 6th when u've only got a 5spd! Rubberside down doesnt always mean rite side up!
Last post Apr 08, 2005, 01:00:39 PM
by BamaToy
Last post Feb 18, 2006, 07:46:05 AM
by 79coyotefrg
Last post Feb 26, 2007, 09:34:10 PM
by Wermz84
Last post Apr 27, 2008, 08:33:24 PM
by Cheesemaker
Last post Jul 09, 2010, 09:53:59 AM
by kneedownnate
