does someone make fj 80 cross drilled and slotted rotors?
Started by yotadork83, May 03, 2007, 05:02:57 PM
yotadork83
likw the title says does someone make fj 80 cross drilled and slotted rotors?  if so where and how much and if not would ifs cross drilled and slotted rotors be as good or better than regular fj 80 rotors. because lc engineering sells them pretty cheap and i always use the crap out of my brakes and now i have much bigger tires so i know i will warp non cross drilled and slotted rotors. what are your guys suggestions.
http://www.toyotacatalog.net/M1WebGear/ProductSearch.aspx?Class=13052
yotas 4 life homie!
yotadork83
yotas 4 life homie!
