0 Members and 6 Guests are viewing this topic.
get the cat changed out and let us know, since it started heating up after you welded up the exhaust leak im sure its a plugged up cat
Put the 180 thermo back in too, its not going to run cooler with a 195 in it.
x2.. why would putting a hotter thermostat cool the engine???just curious?
Because it allows the coolant in the radiator to cool longer. That is why a 160 degree thermostat won't make your engine run cooler. Factory spec is 195 anyway.And, this was doing the same thing before the 195 was put in. Regardless of what thermostat is in it, its not the problem.
WRONG!
WRONG! Once the thermo opens it mixes with the hot coolant in the engine to maintain the temperature. A 160 thermo will maintain 160 in the winter ambient air temps are to hot in the summer to maintain 160.
normal opertation, the thermostat was design to stay open after reaching operating temp. Meaning it doesn't need to close to keep the coolant in the radiator to lower the temp. t-stats primary purpose is to decrease warm up time.on another note, still have the fan shroud?
That is more or less what I said. Fact of the matter is that when its 85+ degrees outside, and you are running a 160 degree thermostat, it doesn't necessarily mean that your motor is running at 160. Its likely running much warmer because the thermstat remains constantly open. Same thing as not running a thermostat at all. The coolant in the radiator never gets cool enough to keep the motor temps down because the thermostat is always open.
WRONG! The thermo's job is to maintain engine temperature and aid in warm up. It does this by controlling the amount of coolant passing through it, But once open it can only restrict so much,not running a thermo does not allow enough time for the coolant to pick up enough heat from the engine, as the cooant flow is too great. The gauge may read 180 or 190 but the engine is much hotter. A good way to blow a head gasket is to not run a thermo.
Well you do what you want you will find out some day. There is no way putting in a 195 is going to make it run cooler than having a 180.
butt I think where he was going was having it open less time would give the water more time to soke in the rad.butt a themo is not just a fully opened or closed thing all the time, it can just open a bit if need be. ie a 195 thermo @ 193. it will be open some of the way butt maybe not all the way.any way sounds like the rad is shot.
Started by 95TacoTruck General 4WD Discussion
Started by Phazertwo Toyota Pickup/4Runner Tech 1979-95
Started by Tallchevy Parts For Sale
Started by snowshoebrue Parts For Sale
Started by 87Fontana Engine
