I don't have a CV, my pinion angle aint too bad, and no vibes. If you are at 108" you should be good with a stock shaft. I am at like 112/113 using a stock single cab/shortbed shaft but I only have about and inch of engagement at ride height.
build a square shaft in the front and shorten the rear. if ya got hubs the square one will never spin unless its in 4wd. if you use 4hi a lot than i wouldnt recomend it. mine doesnt start to shake untill i hit about 30 which is way past the 4low limit.
Started by Rick General 4WD Discussion
Started by snowshoebrue Parts Wanted
Started by bruiz05 Toyota Pickup/4Runner Tech 1979-95
Started by GreenYoterKrawler Engine
Started by IFS Toy Crawler Transfer Case/Drive Line
