4runner acceleration problem
Started by max, March 25, 2004, 05:54:13 PM
max
This is hard to explain.  I have a 89 V6 4runner.  If I am reving it and push the pedal in slowly it revs fine, it i give it a deep quick push it doesn't make a nice growl it sound like it is choking, like it is lean or rich.  If I am driving and I attemped to accelerate quickly it sound like it is dieing again, but if I slowly give it gas it seems to pull stronger.  It runs good though.  I changed spark plugs, distributor cap and rotor, and the air filter is clean.  IT use to sound better, like a good VOOM.  If I smash the pedal to the floor when driving it jumps up and goes like its on crack, and on the high way it seems like the same deal, it does not have much power unless give a LARGE doss of pedal.  Please help, I know it is somthing small so it makes me mad it is not running tip top.
brainlessfool
check fuel presser reg. presser sould jump up when you hit the gas padle. if it don't, change your press. reg.  just my $.02
Prismo
It could also be the fuel filter.
BLUCRUZ
Fuel filter, clogged injector, clogged/dirty air filter?
72 FJ40. 350 Multiport EFI, turbo 400, ORION T-case, 35 Procomp's  disk brakes front & rear, ARB's F&R and an onboard shower for the ladies!
86 sr-5 4runner SAS conversion. E-lockers F&R, 5.29's 4.7 Marlin case.
84runner
gferris5
check your timing too, my truck was doing similar things, turns out the timing was 3 degrees retarded, bumped it up, and it's all good.
