Diff protection
Started by surfindave, March 22, 2004, 05:01:27 AM
surfindave
Hi Guys
Another question for ya.
Do you know anyone who makes a diff guard for the rear toyota axle that is a bolt on or any type for that matter.And front for when i do the SAS
Im getn into rocks and find im slowly wearing away my diff housing at the bottom and around the drain plug also the bolts that hold the 3rd member in get a bit close for comfort any ideas????
Dave
84runner
You take a 8 inch pipe cap and cut it in half. Then weld it to the diff, and buy a low profile drain plug.
mr4x42u
you can also fill in the drain plug and grind it all smooth..Then if you need to change oil in it just pull a bottom stud..Takes longer but better then fighting a boogered drain plug..as for the diff prtection like runner said..get a 8' weld on cap from a pipe sullpy store and cut it in half..Notch the top for the full plug..notch the botton for a drain and then you have one front and rear..
yotaboy79
#3
go to www.allprooffroad.com, they got some pritty good ones for a good price and they have low profile drain pugs :flamer: :_order:
yotaboy79
#4
holly $hit i take that cheap part back i remember them being like 20 bucks, there almost 70 bucks flop that!!! make ur own
Marlin sells them for $20, doesn't protect the whole dif like all pro's but i would buy it.
