My runner is a gross polluter
Started by AaronB, April 11, 2007, 04:58:51 PM
AaronB
Just had it smogged and the HC (PPM) failed at 277 the max allowed is 270  :down:. I think it might be something with the air/fuel. It just doesnt idle right. This sucks! now I have to take it to a gold service tech and pay more money :shudder:
Man, that sucks!  I always ask them to sniff the tailpipe first and abort the test if it doesn't pass.  It's saved me once.
brainlessfool
always ask for a pretest. if they won't go some where elas.
MiniSimp
What did you fix/clean/adjust before the test?
86bobbedtoy
sorry to hear that, but sounds like you will pass fairly easy. the referees are rude as hell but will help a little.
AaronB
im not sure what the deal is. The motor is a brand new rebuild. The guy i bought it from is the one that put it in so there is probably something not hooked up right. I havent really checked it out, I just did a visual of everything to see if there was anything out of place.
iNfErNaL
Quote from: Aaronb on April 11, 2007, 08:25:50 PM
Damn dude,I wish I would've known before you took it.I could've got you hooked up.
WWW.GLOBALOFFROADSUPPLY.COM
Support Your Local Brawlers
www.RockBrawlers.com
www.offroadtruckshow.com
dang i love Arkansas,  when the bugs get bad in the summertime i dump a couple qts of atf  in the gas tank  and  fumigate  :smoke:
86bobbedtoy
Quote from: 79coyotefrg on April 11, 2007, 08:38:44 PM
YEAH BOY.
AaronB
Quote from: Infernal on April 11, 2007, 08:34:27 PM
Yeah, I just figured everything would be good. Thats what I get for not doing the work myself.
MiniSimp
AaronB
Quote from: MiniSimp on April 11, 2007, 10:00:51 PM
What was your timing set at?
I have no Idea. I havent even messed with it yet.
Didn't even consider timing!  I believe you have 3 degrees leeway either way, so you can retard it 3 degrees and pass a little easier.  I believe this is often the cause of the "my truck had more power before I got it smogged, what did they do?!" comment.
AaronB
well it ended up being a vacuum leak. He also said I need to change the intake manifold gasket which didnt make any sence because it was just replaced with less than 30miles on it.
