after cutting rear frame what size metal
Started by Jakesteads, April 04, 2007, 01:15:12 PM
Jakesteads
what size metal is everyone using to make the rear cross member after cutting down the frame.... this truck im buying has the rear end cut off but they never cross membered it.... ive seen where people have used square tubing but i was wondering what thickness.... im planning on welding on some d-ring tabs as well unless something thinks i shouldn't let me know!
I like Toyota
Jakesteads
you think that will hold up for recovery too
I like Toyota
MiniSimp
alwayzbroken
1/4" is pretty beef. Put your tow points near the edges, cap the ends, and gusset the top and bottom of the shackle mounts.
Rockcrawlintoy
i used 2x3x.25 on mine and i have pulled in 2nd gear with 30 foot runs with no issues
Drew
Resident Jeep Guy
2007 JKU All Stock
ECV 7-11
sloyota
this is what i did.1/4 inch with cross braces
I'm not responsable for my own action's.
sloyota
