I'm currently performing my 4.3L / Auto conversion and I'm going to run dual cases behind the 4L60E. The 4L60E has a 3.06 first gear and I was told by somebody not to do 4.7's in the rear case as it'll be too hard to hold back.(torque converter issues). My question is, it seams to me that the torque converter transfers power to the transmission based on engine rpm, not transfercase gear ratio, right? How does this effect the ability to stop the vehicle? I'm going to put 23 spline inputs in both cases, so I figured why not do a 4.7 gearset in the rear which comes with a new input shaft. I know some of you, including somebody at Marlin, have automatics with dual cases, What gears are you running and how is it to drive, on and off the trail. If it matters, I'm running 5.29 R&P with 40" tires
