and make sure you do your measurments on level ground....
only use a level if your on level concrete
Yeah, when my truck was IFS I ran RANCHO torsion bars for about six months, they were a couple of MM. bigger, and better spring rate. There is alot of performance to be gained from an improved spring rate. :drool:To control the additional unsprung weight of a larger tire/wheel combo, the stock bars should be upgraded. It is cheap and bigger bars can take "cranked in" lift and off roading no problem. My
Started by bluetoy84 Engine
Started by AmBush175 Toyota Pickup/4Runner Tech 1979-95
Started by rrick Toyota Pickup/4Runner Tech 1979-95
Started by 82toycrawler Toyota Pickup/4Runner Tech 1979-95
Started by yoter4x4 Toyota Pickup/4Runner Tech 1979-95
