Coil spring suspension ????
Started by Thumper, March 14, 2004, 09:16:26 PM
Thumper
Ok im putting a 4runner rearend out of a 95 and up toyota 4runner under the back of my 82 and i am wondering about doing the 4link suspension, is there any good sites out there that gives the math problems or any way too figure out how long i should make the links.
Ive been reading in the peterson's 4wheel and offroad mag and they showed some stuff how too do it but dident go into real depth on it and kinda confused me. :help:
Any help you can give me pics or sites that have done this would be greatly appreciated.
Thanks :bowdown:
adam
krawlr
27-AT, some other adapter, flipped D300, twin sticks on cables.
[shamelessplug] www.krawlr.com [/shamelessplug]
Don
84runner
You need to look up some books. Chassis Engineering by Herb Adams, Fundamentals of Vehicle Dynameics by Thomas D Gillespie, and Race Car Dynamics by Milliken and Milliken. Here you will get more info and opinions than u will know what to do with. And these books are mainly street use but have good info. To find out what you length of your links will need to be you will need one of these books, a calculator and a piece of paper. Good luck
mr4x42u
once you read up a little from the link krawler posted it will be a little bit better to understand..Areostar coils work real well..
Thumper
Hey im in the process of reading the link Krawler posted i just wish the pics still worked, and what springs would everyone suggest you said areostar coils, is that the company?
Does anyone have any pics on there buildup they did.
This weekend im going too go see the guys at wagoneer machine and take abunch of pics of there rigs and get some help from them.
i have a short wheelbase frame laying in the back yard im thinking about using it too mock up all my links and tack weld every thing under it and make shure its gonna work good before i tear appart my 82 so i dont have much down time but my wheeler is a 82 long wheelbase frame do you think it will hurt too do the mockup on the shorter frame sence im gonna be using the same stuff on the long frame just in a lil diff location prob.
Does that make sence?
Also should i just go ahead and do the front at the same time as the rear or leave it leaf springed for now its got rear springs up front, and flexes pretty good right now i can flex the front left about 3 ft off the ground before the back starts comeing off the ground but with coils in the rear that would help alot.
Pics needed.
Thanks guys
adam
#5
Uhhhh no aerostar isnt a company its a van made by ford.  Heres mine no you cant have the springs!  Everyone uses the rear springs.
84runner
 :laugh: I thought thats what you ment
krawlr
#7
Here's the setup I did on my Taco: http://www.krawlr.com/TacoTech/axles&suspension/Rear/rear.html
The things I got most from that thread: Longer is better.  From a side view, drawing imaginary lines extending your links to the point that they intersect, they should cross just above the vehicle center of gravity.
How do I find the center of gravity you ask? I used the scientific "best guess" method and figured it's between the seats behind the shifter on my rig. :greengrin:
Don
krawlr
Also I used black pipe for my mockup work when I could. Don't want to cut that DOM untill you're 100% sure. :)
Don
Thumper
hey guys thanks for all the help and thanks for the site and info krawler ur helpin me out alot.
so what do you think of the coils you used do they flex good enough ill post some pics of what im going too use tomarrow if i can get time im thinking about using stock rear 4runner coils becuase i have alot of them left from a dealership here that we got back on recalls, so if i bend one or stretch one i can just grab another from the pile.
do you have any more pics of the adjustable ride height set up you did thats pretty cool and does it mess up the angle of the 4 link when you adjust it.
thanks again
adam
Thumper
hey crawler i was checkin out ur site pretty cool did you decide too coil the front too i am going too coil the back i know but cant decide on the front too just leave it leafs or coil it and if you did coil it how hard was that?
thanks
adam
krawlr
That's my second set of coils. Started with stock TJ front coils but with all the gear I carry I switched to 2" lifted TJ coils from BDS. I cut one coil wrap off of those to get the height I wanted. Definately grab whatever freebie coils you can get your hands on and experiment. The Areostar coils are long and soft, I carry too much gear to use them myself but they would work good on something lighter.
I originally designed the top mounts to be adjustable but now I just let them slide. They are made from 2" trailer receiver parts. You can see how they slide out here:
The front is on airbags. I used a full size Bronco axle with the Duff radius arms made for the Bronco. Got some info here: http://www.krawlr.com/TacoTech/axles&suspension/Front/frontaxle.html
Don
84runner
Your best point of reference for you center of gravity line in the top bolt on your bellhousing.
lhack524
Nice rig! looks fun to wheel, but whats up with the "Mad Max" looking grill?
krawlr
Quote from: lhack524 on April 09, 2004, 12:29:57 PM
I've helped reopen logging roads for trailriding here in the midwest. The sapling trees that take over the road like to poke holes in your radiator. :mad: The grill keeps them from getting that far before they get snapped. :thumbs: Saves lots of footwork with a chainsaw.
For the enviromentalists: These are roads found on current mapping software 2004 version, on private property, with permission directly from the owner(s) in person. :shake: ::) :shake:
Don
Jimmyg
Haven't learned to Crawl Yet but I'm gettin ready to!
krawlr
Don
84runner
krawlr
Quote from: 84runner on May 12, 2004, 04:54:31 PM
Link works for meĀ  :thumbs:
Finally viewed it on another computer. Looks like some nice work. :thumbs:
My comp has scripting issues, that's the first page that just wouldn't load at all. :mad:
Don
Jimmyg
I gotta stay off this puter till I finish puttin the front axle back under Red  :smack: Too many good ideas floating around I just get started and its time to change my plans to incorporate some other upgrade  :laugh: :hahaha: :yupyup: :beerchug:
