Author Topic: t-case gaskets  (Read 1252 times)
pyrotec220
  • Male Posts: 218
  • Member since Nov '05
  • rock solid
    • myspace-- although i use facebook
t-case gaskets
« on: Mar 24, 2007, 11:47:40 AM »
does anyone know if you can just buy one certain t-case gasket? I need the one that is for the coverthing on the front output. I tried makin a gasket with some silicone but it seems like it didnt work because when i put oil in the case i have a slow leak. Maybe do i just need a cetain kind of silicone? i was thinkin maybe the reason the silicone wasnt working is because i am runnin synthetic oil and people say that it wears out gaskets and silicone. Just wonderin if anyone has any ideas or suggestions
Thanks
Dan
toynorcal
  • Turtle Points: 96
  • Male Posts: 435
  • Member since Jul '05
  • "Easyline"
Re: t-case gaskets
« Reply #1 on: Mar 25, 2007, 09:43:42 PM »
sythetic oils don't cause leaks, they just find them better than regular oils do. I used silicon (black) because I din't want to make another run to the parts store and it works fine. I would just suggest re-sealing it and letting the silicone set up for a good 20 min (or until it gets a slight skin) before bolting them together. Aslo maybe wait through the afternoon or untill the next day before you refill the case.
Duffil
  • *lurker*
  • Turtle Points: 138
  • Male Posts: 4,844
  • Member since Nov '04
    • PhotoBucket
Re: t-case gaskets
« Reply #2 on: Mar 26, 2007, 02:30:06 PM »
Anaerobic sealer works great also, but it's a little pricey compared to sillycone.
pyrotec220 [OP]
  • Male Posts: 218
  • rock solid
Re: t-case gaskets
« Reply #3 on: Apr 06, 2007, 06:56:05 AM »
Thanks guys. ya i did some research and gray and black seem like the best bet. i used the high temp copper cus thats what i had and i let it sit for about 45 minutes and then bolted together and i put fluid in the next day. didnt work  :shake_head: , but i will definately try black or grey cause i have heard multiple people say it works :thumbs:. I have never heard of Anaerobic sealer before. maybe ill check it out but i am on a tight budget so you know how it goes. Thanks Again!  :beerchug:
Dan
insane04
  • Turtle Points: -64
  • Male Posts: 390
  • Member since Feb '06
Re: t-case gaskets
« Reply #4 on: Apr 06, 2007, 08:16:23 AM »
Anaerobic sealer is the way to go!!!!
pyrotec220 [OP]
  • Male Posts: 218
  • rock solid
Re: t-case gaskets
« Reply #5 on: Apr 09, 2007, 07:55:10 AM »
just wana let you know i used grey sillycone and it seems to be working! says its for imports and is highly resistant to oils.  thanks for all the help!
fullthrottle
  • Male Posts: 177
  • Member since Aug '06
Re: t-case gaskets
« Reply #6 on: Apr 10, 2007, 04:01:54 AM »
there is sealer called  [the right stuff] it is the best don't use a gasget
SASed 94 pu- marlin crawler 4'' springs, 5.29s aussie R lockright F 30spline longs , crawler box and 37'' SSR's
Last post Apr 26, 2007, 11:57:21 PM
by jimbo74
Last post Jun 03, 2009, 09:33:16 PM
by OOPS
Last post Nov 20, 2009, 08:48:51 AM
by Volcom
Last post Feb 12, 2010, 08:51:47 PM
by crawlerdan
Last post Dec 17, 2020, 05:06:01 PM
by Snowtoy
