will a gear driven case bolt to my transmission or do I need to get an adapter for there as well.
Hello jackedupYJ
![Wave :wave:](https://board.marlincrawler.com/Smileys/marlin/wave.gif)
Yes, you will need an adapter plate to adapt your transmission to a 1979-95 Gear Drive t/case. The Gear Drive has a different bolt pattern than the Chain Drive (what you have).
The Adapter Plate you are looking for is Part Number 34-4GT. It is made from Billet T6061 Aluminum and was originally designed by Marlin Czajkowski back in mid 90s.
Here is what the plate looks like, including the optional 10-degree offset pattern:
![](http://www.marlincrawler.com/images/34-4GT-R10_animated_240.gif)
Once that we have converted you to a Gear Drive T/case, now you are exposed to all of the low range gearing options and dual case adapter available for it.
Since you not only have a V6, but are also a bit on the heavy side, I HIGHLY RECOMMEND using ONLY Marlin Crawler components with your drivetrain. I say this NOT because I work for Marlin Crawler, but I say this because I CARE about your Tacoma not leaving you stranded somewhere.
Marlin Crawler was founded on the "it could be better" belief, where even if changes are not necessary, we have done it just to make it
that much better.
I hate sounding like this, but especially considering your situation,
IN MY OPINION, I would NOT settle for a copy of the Marlin Crawler, nor would I settle for running a discontinued Marlin Crawler design (A/A MC05 & Trail Gear Trail Creeper).
Not only is this my opinion, but I so firmly believe that the Marlin Crawler is the strongest and most reliable Crawler in the world that I have written articles regarding its advanced design.
If you have a minute, please read this article regarding why the Marlin Crawler Dual Case is the most reliable Dual Case in the world:
Understanding the Success of the Marlin Crawler. Please note that this article is not yet finished, and should be soon.
Also, please read these posts regarding the advantage of our Dual Case Design and the Advancements made to our original 4.70:1 Gear Set, the very first Low Range Gear Set marketed in the world for the Gear Drive t/case:
Marlin Crawler Parts ComparisonI hope these articles find you with good intrest. I feel that they are very important and I wish more people knew about how companies have blatantly copied Marlin Czajkowski and all of his hard work..
![I\'m Down :down:](https://board.marlincrawler.com/Smileys/marlin/down.gif)
Regards,
